TOYO R888 QUESTION???
Old May 6, 2009 | 09:52 AM
  #41
Tac-M's Avatar
Tac-M
^ yes... sorry +22 on all 4 in my case.
Old May 6, 2009 | 10:07 AM
  #42
Ataru074's Avatar
Ataru074
Originally Posted by SIR_pierre
yes the tire on the wheels is no problem at all. im worried about it not fitting inside my fenders
today i have 295 vredenstein in the rear and they scratch when taking corners
ouch. well I have to roll my fenders to fit 275 R comp (like R888) tires in my rear on my enkei rims.
Old May 6, 2009 | 10:13 AM
  #43
SIR_pierre's Avatar
SIR_pierre
Originally Posted by scotts300
Depends on the offset, but if your 295 Vredensteins don't fit properly in the rear, it sounds like the larger 295 R888 won't make the issue go away.
Again - depends on offset. YOU may need the rear fenders rolled with more neg camber, but not all set-ups would - especially for a 295-sized tire.
i have plans to roll my fenders. i have 22 offset
how badly are -3 camber? pics of a car with that camber settings?
Old May 6, 2009 | 10:24 AM
  #44
scotts300's Avatar
scotts300
Maybe I missed it - what size are you front and rear wheels at the +22 offset? What size tire do you plan/hope to run in the front?
Old May 6, 2009 | 10:34 AM
  #45
Crom's Avatar
Crom
Isn't -3 + cam on the rear a little counter intuitive for a 295/305 tire for traction ?....shou'd be -1.5 - 2.0 for the best grip to get the most out of the tire.
Old May 6, 2009 | 10:40 AM
  #46
SIR_pierre's Avatar
SIR_pierre
i have the Volk TE37 offset 22 F9.5 R 10.5/19
now i have PSII 255 in the front and vredenstein 295 in the rear.
the only option for me in the front is 265 no mather what type of R tire, i would prefere 255, and i dont think i can fit less then 255.
and in the rear i would prefere 285 if there is. otherwise 295
the rear tires scrapes my non rolled fenders when i push it in the corners, but so did my PSII in size 285 aswell.. but i think we have confirmed that they are more or less just as wide
Old May 6, 2009 | 10:45 AM
  #47
Tac-M's Avatar
Tac-M
wait. for the rear - i am @ -2.1 and i hope for a few points more so it would be closer to -3
now the fronts are getting adjustable a-arms so i can get -3 or more.
again my car is track only.... and i need corner grip - not 500whp of the line grip...
and here is what toyo recommends
Toyo Tires recommends the following general set up guidelines for the Proxes R888:
* Operating Temperature: 160°F to 220°F
* Hot Inflation Pressures: 32 to 38 (psi)
* Camber: -2.5° to -5.0°
* Caster: As much positive as possible
JET - would you share what you run in terms of alignment ?
Old May 6, 2009 | 10:48 AM
  #48
Tac-M's Avatar
Tac-M
i had to roll fenders with a 275 advan sports on the same wheel setup...
so you will need to roll REAR fenders for sure. if you don't track - i would not suggest running r888.
Old May 6, 2009 | 11:52 AM
  #49
Crom's Avatar
Crom
Also take into consideration the amount that your dropped...My old 295 ps2's still rubbed in the rear on my +22 LE's w/ my fenders cut/ my camber at -3 +...I was not happy w/ the fitment hence switching to a 285 street tire.
Old May 6, 2009 | 12:05 PM
  #50
SIR_pierre's Avatar
SIR_pierre
more or less only do track.. just afraid of cracking the paint when they roll my fenders
Old May 6, 2009 | 02:00 PM
  #51
Ataru074's Avatar
Ataru074
if they properly use the heat gun they shouldn't crack the paint...
btw. nothing that a fair amount of touch up paint can't fix.
if you track your front bumper and hood should be already a mess from sand and small rocks from following other cars.
otherwise trade in your rear wheels, go 9.5 all around and use 265 all around.
Old May 6, 2009 | 11:36 PM
  #52
SIR_pierre's Avatar
SIR_pierre
Following other cars? dont understand what you mean
but yes the front is messed up. no i need as wide as possible in the back since the car just burn tires untill i put in 4th gear
Old May 7, 2009 | 12:00 AM
  #53
JETPILOT's Avatar
JETPILOT
I am currently running -3.0 camber up front and -2.0 camber in the rear. For my driving style, suspension setup, and track (sebring) I find this setup prefect.
Old May 7, 2009 | 04:04 AM
  #54
Tac-M's Avatar
Tac-M
^ thanks jet ! that's what i am going for !
spl v2 a-arms.... yay !
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
