20x10 wheel up front
Old Nov 8, 2008 | 09:07 PM
DUBZRO's Avatar
DUBZRO
Default 20x10 wheel up front
hey guys... don't know if its been covered but im using my fone to log in so I can't search as great as i 'd like to... anyway I need to know if I can fit 20x10 up front with a 35 offset on stock height. and if so what tire size should and could be used. greatly appreciated .
Old Nov 9, 2008 | 10:47 PM
An offset calculator is a great tool. Try it.
Old Nov 10, 2008 | 12:24 AM
redlude97's Avatar
redlude97
I have a feeling that offset is going to be too high and have clearance issues on the inside
Old Nov 10, 2008 | 03:01 AM
Z04's Avatar
Z04
it would fit a SUV
Old Nov 10, 2008 | 04:17 AM
350z-Jim's Avatar
350z-Jim
I highly doubt a 20x10 would fit. There just isn't the clearance in the front to run a wheel that wide. Why would you want to? A 20x8 or 8.5 would be a way better choice. A 245 easily fits on an 8 inch wide wheels which is plenty of meat for the front wheels.
Old Nov 10, 2008 | 09:00 AM
redlude97's Avatar
redlude97
Lots of people have run a 10" wheel in the front, it just takes the right offset to get it to clear
Old Nov 10, 2008 | 10:58 AM
terrasmak's Avatar
+20 to 30 will be what you need. What size tire do you plan to run?
Old Nov 10, 2008 | 01:06 PM
DUBZRO's Avatar
DUBZRO
thanks guys for the help.
as far as an offset calc, i tried it thanks but a word from those who have actually done it or have knowledge of wheel size/offsets rather than a computerized calculation doesnt hurt.
I plan on running 255/35 and a 10 or 15mm spacer
Old Nov 10, 2008 | 01:18 PM
Done Deal DR's Avatar
Done Deal DR
I have a 20.9x5 in the front, a 20x10 COULD fit. Unfortunately I don't know what offset my setup is as iForged doesn't release them, but I can tell you that if your offset was perfect a 20x10 would fit. That said, I highly doubt a 35 offset would fit right. On stock height you can just about fit anything given it doesn't hit any suspension components or your fender well, but I don't think a 35 offset is the answer.
Old Nov 10, 2008 | 01:31 PM
DUBZRO's Avatar
DUBZRO
thanks, i will be using spacers so offset will be lower, just not sure how low until i get the wheels on there, then we will try dif size spacers til i get a good fit. thanks again
Old Nov 10, 2008 | 02:10 PM
Done Deal DR
If you already have the wheels, put them on (or attempt to) and see how large of a spacer you need. Like I said, you will need to have a perfect offset to pull it off. That said, it's probably not even worth it, it's going to weigh a ton more than likely.
This will allow you to get a good idea of the size of space you need and not just go buy a ton of them and try them all out, unless of course you just have a ton sitting around...but I don't know why anyone would.
Obadabot
Jun 18, 2023 11:31 PM
