Review of A-Arm for less tyre wear
Old Nov 30, 2008 | 05:50 AM
lanceccs's Avatar
lanceccs
Default Review of A-Arm for less tyre wear
I read about
Cusco A-Arm
Kinetix A-Arm
So far, the read of Kinetix seems to be better for reducing tyre wear. Anyone has any other good recommendation?
Thanks in Adv.
Old Nov 30, 2008 | 06:28 AM
laze1's Avatar
laze1
SPL street or race A Arms are great!
Old Nov 30, 2008 | 09:48 AM
bighungrydewees's Avatar
bighungrydewees
Originally Posted by lanceccs
I read about
Cusco A-Arm
Kinetix A-Arm
Thanks in Adv.
Don't go with Kinetix! I hate to knock any brand, but I have my reasons. (Cars been sitting in garage for like a month now due to the evil little a-arm)
Old Nov 30, 2008 | 10:35 AM
terrasmak's Avatar
Megan and Cusco are pretty much the same. I've had no problems with my Megans , and beat the living **** out of my car.
Old Nov 30, 2008 | 10:52 AM
lanceccs's Avatar
lanceccs
Could you give more details on what happened?
So far I have not shortlisted Cusco as I am told that it don't allow positive camber adjustment.
Kinetix is the one I have shortlisted as it is rather affordable and has ready stock.
Can someone comment about SPC?
Old Nov 30, 2008 | 11:05 AM
bighungrydewees
Well, to sum it up, after making 3 adjustments the both the bolt and nut's threads are gone with the wind.
I know some of you right now are thinking, "man this idiot cross threaded or over tightened". I don't blame you for thinking it but it's not true. The tollerances b/w the nut and ball joint's bolt were way to close. It was like screwing on a lock nut that was like the strongest lock nut ever, even when the arms were new.
Ok, sorry I know I'm rambling. Other reason these arms may not be a good choice is the fact that if you're car is lowered enough (I'm 1.5"), you have to run a certain amount of negative camber just to keep the a-arms ball joint from rubbing the upper fender. In fact, if I would have tried to run like -1 camber (been running -1.8) when I first installed them, they would have probably bent my upper/outer fender.
SPC is a good choice.
Old Nov 30, 2008 | 12:18 PM
JETPILOT's Avatar
JETPILOT
The best A-arms are from 350Evo.com
They make the only forged aluminum arms, and they come with solid bushings.
Old Nov 30, 2008 | 12:21 PM
bighungrydewees
I'm glad you brought that up JETPILOT. I'll be purchasing a set in the next week or two. Also, they are on sale right now. They are probably the best of the best guys.
Old Nov 30, 2008 | 01:35 PM
=Cerberus='s Avatar
=Cerberus=
Those A-arms are pretty sick. They are incredibly expensive though.
emooheo
Oct 14, 2015 08:58 AM
nanotech
Oct 2, 2015 05:02 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
