245/275 setup vs. 255/285
Old Dec 22, 2008 | 09:20 AM
  #41
Steve-O Z33's Avatar
Steve-O Z33
There really isn't much difference between 275 and 285. If the 275 is substantially cheaper, I'm going with it. If it's like $20, I'll probably go up to 285. 285=flush sidewall, 275=slight curve. This is probably the best 275 fitment I've seen on a tire yet. Thanks guys! I think I've found my tires!
Old Dec 22, 2008 | 10:06 AM
  #42
coolblue830's Avatar
coolblue830
Originally Posted by Steve-O Z33
I believe I speak for most of us when I say...
WOAH.
Old Dec 22, 2008 | 08:49 PM
  #43
scotts300's Avatar
scotts300
Originally Posted by soleil350z
its really not bad with the 245/275 setup....
245s do not belong on 9.5" wheels. It will be stretched, and look out of place with an otherwise beautiful set0-up.
I don't think 275s belong on 10.5s either, but the 245s on 9.5s is a worse match.
Old Dec 25, 2008 | 01:43 PM
  #44
350ZPK's Avatar
350ZPK
I am starting to hate my 245/275 setup
Go with a 255/265 and 285/295 setup
Old Dec 25, 2008 | 10:54 PM
  #45
OldDirty Z33's Avatar
OldDirty Z33
255/40/18 275/40/18 ftmfgdw
Old Dec 26, 2008 | 09:06 AM
  #46
terrasmak's Avatar
+1 , but i'm going to do the 275 295 combo next if i go FI.
Old Dec 27, 2008 | 09:47 AM
  #47
RED RIDER's Avatar
RED RIDER
I like my setup...
Old Dec 27, 2008 | 10:32 AM
  #48
BhashaZ's Avatar
BhashaZ
Originally Posted by Triple8Sol
It depends on the tire. Some have thicker sidewalls than others. A 245/275 Advan Sport or Michelin PS2 is as beefy as a Toyo/Falken 255/285
Well, you got plenty of replies to make your decision, but FWIW, I have a 19x9.5" +19 and 19x10.5" +17 wheel setup, which is pretty close to the GT-S offsets in the same size.
Anyways, I have always ran Toyo T1-R's, but so far I have run:
1. 245/35/19 and 275/35/19
2. 255/35/19 and 275/35/19
3. 255/35/19 and 285/35/19 <-- next week
I can say that setup number one was not to my liking, because the 245/35/19 was too stretched. The current setup I have right now is great, since it gets rid of the stretched look up front. However, the rear 275/35/19 is SLIGHTLY stretched on the 19x10.5" wheel, although nowhere nearly as bad as the 245/35/19 was on the 19x9.5" wheel.
Next week I should have on the 285/35/19. I have no issues with the 275/35/19, but just wanted a little more rim protection, so I decided to go with the 285/35/19 in the SAME Toyo T1-R tires. I have already gotten my fenders rolled, but since Toyo's tend to run narrower, I hope that I shouldn't have any issues. I had wanted to run a 295/30/19, but I had to step up to Michelin PS2s, Pirellis, or Continentals, which were a LOT pricier, and tend to run wider than the Toyo's do. Toyo T1-R doesn't come in a 295/30/19 offering, or that is what I would have gotten.
Also, you can look here for more information (although pix may not work, but good info):
https://my350z.com/forum/wheels-tire...35-19-a-2.html
Just as a note, the 255/35/19 and 275/35/19 will give you less understeer than a 255/19/19 and 285/35/19 because there is a 20mm stagger front-to-rear with the former vs a 30mm stagger with the latter.
Good luck!
350Z_Al
Oct 29, 2020 07:44 PM
_koubie_
Sep 20, 2015 06:34 PM
