Anybody running 255/35/18 tires?
Old Dec 22, 2008 | 07:50 PM
Triple8Sol's Avatar
Triple8Sol
Default Anybody running 255/35/18 tires?
Just wondering if anyone runs this tire size front and/or rear? If so, can you list what the width/offset of your wheel, and also the brand/model of the tire? Thank!
Old Dec 22, 2008 | 10:37 PM
Chebosto's Avatar
Chebosto
i ran Toyo R888s in a 255/35/18 on a +15 18x9.5 RE30 with 295/30/18 on a +18 18x10.5 RE30 for the Import Tuner shoot i did. The 255/35 R888 came in with a tread width: 10.1" & overall diameter: 25.1". The 295/30 tread width was: 11.8" and o.d. 25.1".. However i would not recommend either size due to the o.d. size and resulting gearing changes.
Old Dec 22, 2008 | 11:13 PM
Triple8Sol's Avatar
Triple8Sol
So basically that tire size is never run on front or rear Z/G wheels then?
Old Dec 23, 2008 | 05:26 AM
z-u-later's Avatar
z-u-later
Well, you can but they're shorter. If you're thinking going square with this tire size, it is really more ideal for the track. I have a set of race slicks with 255/35 in front and 285/35 in rear -- both are ~25" tall.
Old Dec 23, 2008 | 05:57 AM
AznSky's Avatar
AznSky
I plan on running 265/35/18's Direzza Star Specs all around on (4) 18x8.5 +33 track wheels this upcoming year.
Both DD and weekend track use.
Old Dec 23, 2008 | 06:00 AM
Motormouth's Avatar
Motormouth
I downsized to a 255/40/17, 275/35/18 combo
just make sure your F > R rolling diameter is still close. and know that you will have alot more fender gap.
Old Dec 23, 2008 | 09:37 AM
terrasmak's Avatar
I've seen it done and it looks pretty lame. The outer tire doesn't match the wheel well arch anymore. For the track , who cares, just do it.
Old Dec 23, 2008 | 12:15 PM
Triple8Sol's Avatar
Triple8Sol
True. I was asking for street, so thanks everyone for quickly coming to a consensus.
