Wheel size and offset question
Old Jan 3, 2009 | 03:19 PM
adulay's Avatar
adulay
Default Wheel size and offset question
I'm thinking about buying some 20" Volk GT-7 wheels for my '06 350z. The specs are 20 x 9.5 (offset: +22) up front and 20 x 10.5 (offset: +24) in the back. The tire set-up is 245/35/20 and 275/35/20.
My question is whether I can achieve an aggressive look with this set-up and if the wheels will be flush with my fenders (possible stick out a tiny bit in the back ? Sorry for the noob question, I am new to the forums! Thanks!
Old Jan 3, 2009 | 03:55 PM
Jose2008Z's Avatar
Jose2008Z
you would need a spacer to achieve the more aggressive look. Probably a 15mm or maybe even a 20mm spacer. Depends on how aggressive you want to go... Ask some of the experts in the stretched/aggressive wheel thread...
Old Jan 3, 2009 | 04:15 PM
galant350z's Avatar
galant350z
No, you’re not running savage offsets nor do you need aggressively stretched tires. The wheels should be flush against the fenders. You probably need spacer if you want the rear to stick out.
Old Jan 3, 2009 | 06:56 PM
adulay's Avatar
adulay
thanks for the suggestions guys! other opinions are appreciated as well!
Old Jan 3, 2009 | 09:23 PM
str8dum1's Avatar
str8dum1
for aggressive you'd need spacers and 225 and 245 tires.
what you spec'd is run of the mill. it will look like every other volk setup.
Old Jan 4, 2009 | 09:26 AM
adulay's Avatar
adulay
bump
Old Jan 4, 2009 | 09:42 AM
GooDy151's Avatar
GooDy151
You will be good flush but not "rolled fender flush".
Old Jan 4, 2009 | 12:28 PM
adulay's Avatar
adulay
hmmm ... interesting ...
Old Jan 4, 2009 | 01:53 PM
Stretch is the rage. Destroys the sidewalls but what the hell. Looks cool. That’s what counts.
Old Jan 4, 2009 | 03:33 PM
djnc's Avatar
djnc
275/35/20 tires will look stupid...you need 275/30/20
Old Jan 4, 2009 | 03:38 PM
calin's Avatar
calin
+1...I think 275/35 will look a little bit too "beefy" on 20's
Old Jan 4, 2009 | 04:13 PM
Done Deal DR's Avatar
Done Deal DR
30 series is the ticket for 20" rears. Having a nearly identical setup, I would suggest a 275/30/20 for a bit of a stretch, and 285/30/20 for a bit more meet.
If I stick with these wheels, I'll likely go to a 285/30/20 or 295/30/20.
Old Jan 4, 2009 | 08:27 PM
galant350z's Avatar
galant350z
^+1, i be running 255/30/20 and 285/30/20
Old Jan 5, 2009 | 10:18 AM
adulay's Avatar
adulay
Thanks for the advice guys!
seagrasser
Oct 11, 2015 03:27 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
