Proper offset for my z??
Jan 26, 2009 | 08:26 PM
What size offset is the best so i dont have to run a spacer and have a flush fit?
Jan 26, 2009 | 08:37 PM
Jan 26, 2009 | 10:53 PM
Super Moderator MY350Z.COM
What do you consider flush? Are you planning on rolling your fenders?
Jan 27, 2009 | 03:58 AM
Jan 27, 2009 | 04:49 AM
pick a wheel then come back.....
Jan 27, 2009 | 04:54 AM
pick a style then pick your size then come back.
Jan 27, 2009 | 05:42 AM
Quote:
Originally Posted by
Kneeson350z
depends on the size (diameter and depth). but since you do not know i suggest you stick with the OEM wheels until you figure it out.
Jan 27, 2009 | 06:08 AM
you need a 9.5"f 10.5"r wheel with 12mm offsets.
if you want wider or narrower use
http://www.1010tires.com/WheelOffsetCalculator.asp
and type in the new rim width and keep changing the offset until it matches a 10.5" rim with+12 offset.
Jan 27, 2009 | 08:16 AM
Depends on which thread you read the most. Offset depends on wheel width, and wheel width depends on offset. Like crabs and itching, they go together.
Jan 29, 2009 | 01:45 PM
I want to run the rays progressiv me's in a 20 by 9.5 in the front and 20 by 10.5 in the rear...
Jan 29, 2009 | 01:58 PM
most popular offsets are +12 to +22
Jan 29, 2009 | 02:01 PM
m_0g
Jun 3, 2021 10:05 AM
seagrasser
Oct 11, 2015 03:27 PM
Depravity
Oct 1, 2015 04:49 PM
