would i have to roll my fender?
Old Feb 18, 2009 | 08:11 AM
ws m13z's Avatar
ws m13z
Default would i have to roll my fender?
if im runnin a 18x10 +18 (0) in the rear. i also want to add a 15 - 20 mm spacer in the rear. if i drop my car on some stance coils (still waiting for them to arrive) would i have to roll my fenders? (i just want to close my wheel gap -_-) thanks for the help.
Old Feb 18, 2009 | 09:30 AM
fatboy.yoshi's Avatar
fatboy.yoshi
yes definately....
Old Feb 18, 2009 | 09:34 AM
Only if the tire rubs the fender.
Old Feb 18, 2009 | 09:54 AM
Entaille's Avatar
Entaille
don't listen to this insane logic
Done Deal DR's Avatar
Done Deal DR
I'd have to agree with Yoshi.
You're planning on running close to a 0 offset, or even negative offset. You will be lucky if it fits with a roll, stretched tires and negative camber. I've seen it happen before, but it'll definitely take some work and even then it will probably rub on hard corners.
Old Feb 18, 2009 | 09:55 AM
Done Deal DR
LOL
Old Feb 18, 2009 | 10:22 AM
scotts300's Avatar
scotts300
If you run either spacer, you'd need to install a 215-sized tire. That'd look hawt.
Old Feb 18, 2009 | 10:50 AM
terrasmak's Avatar
I'm running an 18x10.5 +10 with a 275/40 , you'll be fine with a roll.
Old Feb 18, 2009 | 06:52 PM
DustinZ33's Avatar
DustinZ33
18x10.5 +-0 265/35 with a roll
Old Feb 21, 2009 | 11:26 AM
ws m13z's Avatar
ws m13z
thanks for all the input guys. now could someone point me in the direction of a good fender roller in so. cal? seems the guys who been doin it stopped. am i wrong?
Old Feb 21, 2009 | 12:29 PM
terrasmak's Avatar
Reginal section can help you with a roller.
Old Feb 28, 2009 | 05:54 AM
Sunset350ZR's Avatar
Sunset350ZR
Guys need to jack this thread. I want to run 18x10+20 offset on the rear without rolling fenders. Is this possible on a roadster?
Old Feb 28, 2009 | 03:11 PM
Sunset350ZR
That would be great but I am in TN.
Old Feb 28, 2009 | 03:30 PM
BarefootRacer's Avatar
BarefootRacer
^^ Im in Nashville and do fender rolling. Have the eastwood tool. PM me.
Old Mar 1, 2009 | 10:34 AM
scotts300's Avatar
scotts300
Absolutely - anything in the 275-285 tire range will be fine. I have run 275, 295, and 305 on our 19x10.5 +28s on our roadster - never with any rubbing. The outer portion of our wheel, is wider than yours by 12.25mm, would be the same as a 19x10 +22, so you're definitely good with 275-285 (even the tires that run "large" like BS RE050A).
Old Mar 1, 2009 | 11:04 AM
daytona350z's Avatar
daytona350z
he was talking to the op.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
