How much TQ for wheel spacers.
Old Feb 24, 2009 | 01:14 PM
frankie945's Avatar
frankie945
Default How much TQ for wheel spacers.
How much TQ are you guys using when installing Spacers ? Like 80lbs per lug...?
Spacers are the Ichiba 15mm V2.
Thanks in advance.
Old Feb 24, 2009 | 04:48 PM
frankie945's Avatar
frankie945
Well.. I Torqued them to 85lbs and used some blue locktite. Had to trim 1/4 inch off the factory studs so they would clear.
Old Feb 24, 2009 | 05:11 PM
sry110's Avatar
sry110
I would think to torque them the same as you would torque the wheel lugs.
Old Feb 24, 2009 | 05:36 PM
Entaille's Avatar
Entaille
bingo.
btw - I had to do the same as you and I've been riding around on them for a couple of months, checked tq, they are staying solid, and this was without locktite. don't stress!
Old Feb 24, 2009 | 06:12 PM
Thumbs up
Sounds good to me.
Old Feb 25, 2009 | 06:42 AM
Swiffer's Avatar
Swiffer
I did mine 90 lbs.
Any of you guys have any suggestions for torquing the spacers on the front wheels? I had to use the bar from my jack and stick it between the studs and then have it stop against my foot to hold the hub from spinning. I got it to work, but it wasnt the easiest thing to do.
Old Feb 25, 2009 | 08:13 AM
sry110's Avatar
sry110
Originally Posted by camaro194
I did mine 90 lbs.
Yeah and it's risky in case the bar slips off your foot and goes flying into your fender or something. One "solution" might be to have a second person get in the car and press the brake pedal down....but then again, I don't want anyone getting in/out of the car while I have it jacked up to work on it.
Old Feb 25, 2009 | 08:23 AM
Motormouth's Avatar
Motormouth
stick a bar between the lug nuts that hits against the fender and you are GTG.
Old Feb 25, 2009 | 08:52 AM
terrasmak's Avatar
Have someone stand on the brakes , if your car is properly supported, someone getting in and out is no big deal.
Obadabot
Jun 18, 2023 11:31 PM
