My planned tire size config. ( assuming 17" OEM wheels)
Old Mar 20, 2009 | 06:43 PM
go_speed_engy's Avatar
go_speed_engy
Default My planned tire size config. ( assuming 17" OEM wheels)
I must shortly purchase new summer tires for my 04 350Z. I have the oem 17" rims. The tires I am considering are SUMITOMO HTR Z III, and I am considering using them in the follow configuration:
REAR: 245/45ZR17 (25.8 in Outer diameter)
FRONT: 235/45ZR17 (25.4in Outer Diameter)
I have not seen discussion of this exact size configuration. If I understand things correctly, this setup should work for the VDC. Still as I couldn't find a specific post about this scenerio, I was hoping for some input. Would this work well? Thank you.
Old Mar 20, 2009 | 07:22 PM
Spike100's Avatar
Spike100
The sizes you are considering will work perfectly on any Z, including a VDC-equipped model.
Finally... someone who does their own homework!
--Spike
Old Mar 20, 2009 | 07:48 PM
Thumbs up
Place your order you are good to go.
Old Mar 20, 2009 | 10:19 PM
go_speed_engy
Thanks to both of you.
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
