Front passenger wheel making droning sound.
Old Mar 24, 2009 | 09:52 AM
Kimosabe's Avatar
Kimosabe
Default Front passenger wheel making droning sound.
Hey guys,
Hoping you can help me with this. I've been experiencing this pulse droning sound from my passenger front wheel. It kicks in at around 15-20mph but goes away after that. Does not have a metal sound to it at all, almost sounds like there is a spot on my tire that is making this sound but I have no clue. Im waiting for the weather to warm up so I can swap on the spare and see if its the wheel itself or something else all together.
I have no idea if its related to the same problem, but when I change lanes and turn the wheels left slightly this pulse vibration sound starts kinda similar to the one at low speeds but you can feel the vibration more so from the same wheel. But this is experienced more so at +60 mph speeds. If inspected the wheel myself, and it seemed fine. I dont think its a wheel bearing issue either.
If you guys have any input before i go to the dealer that would be great.
Appreciate it!
Old Mar 24, 2009 | 10:05 AM
How many miles are on the car?
Tire problem? Need to see photos of tires.
Wheel bearing is easy to check. Grab top of wheel. Pull hard.
Old Mar 24, 2009 | 10:14 AM
ErkTheJerk73's Avatar
ErkTheJerk73
im going to guess wheel bearing... from experience on my Z
Old Mar 24, 2009 | 10:57 AM
Kimosabe's Avatar
Kimosabe
If i do that test how much give am i expecting? There is about 65000 miles on it now. I wont lie, its been doing this for quite some time and it hasn't been getting any worst.
If it was a wheel bearing wouldn't the droning be constant as opposed to pulsing?
Old Mar 24, 2009 | 11:07 AM
If you pull the top of the tire you may be able to feel excess play in the wheel bearing. Also jack up the front of the car. Spin the wheel. A bad wheel bearing will sound like rocks inside the bearing.
Old Mar 24, 2009 | 04:14 PM
SlowCoupe's Avatar
SlowCoupe
try balancing the said wheel.
Old Mar 24, 2009 | 04:19 PM
0jiggy0's Avatar
0jiggy0
It's the wheel bearing most likely, listen to david
Old Mar 24, 2009 | 05:54 PM
SlowCoupe's Avatar
SlowCoupe
i haven't been a tech for long but all the bad wheel bearings i've done made a humming/droning noise that increase with speed and never go away at higher speeds.
also check to see if you tires are feathered.
then again its hard to tell without personally checking it out.
PLAYDIRTY
Oct 12, 2015 07:45 AM
