for haters.. nismo on 17" enkei rpf1
Old Apr 6, 2009 | 05:03 PM
  #61
$LiK RiK's Avatar
$LiK RiK
Thumbs up F da haters
That ish looks F in tough.
Old Apr 12, 2009 | 01:18 AM
  #62
ReV2Red's Avatar
ReV2Red
I haz da turbos
Ah crap! Now i'm going to have to buy a set of RPF1's! lol
Real nice setup, even though i think i'll run an 18 in the rear, and slam the **** out of the car.
Still keep the 19's for the street.
Old Apr 17, 2009 | 12:57 PM
  #63
driftmc's Avatar
driftmc
wow those are awesome 17"ers.
I was looking to get Rota grid 18" but reading more about it I might look into 17" Enkei RPF1s instead!
I've got non-brembo stock "Brakes" now so guess I don't have to worry about clearance...
Awesome track setup OP
Last edited by driftmc; Apr 18, 2009 at 07:10 AM. Reason: oop fail, how did I botch that spelling...haha;;
Old Apr 17, 2009 | 03:48 PM
  #64
terrasmak's Avatar
Originally Posted by driftmc
non-brembo stock breaks
??WFT??
Old Mar 29, 2010 | 05:08 AM
  #65
QTB's Avatar
QTB
Originally Posted by scotts300
Anyone with the 332mm Stoptech BBK and these wheels be warned: You will have a hard time fitting a 275 tire on the front with a 17x9.5" wheel. I had to push my set to a net 17x9.5 +13 to clear the caliper, which led to the tire sticking out well beyond the fender. This was with a 275/40/17 V710 tire and 2.2 degrees of camber. Don't believe me? Well they're for sale, BNIB but mounted with tires for test-fit (tires removed now), for $850. They are 17x9.5 +38 offset because I wanted to use them on my 300ZXTT (no spacers) as well as the track 350 (with 20mm spacers to net a +18 offset), but they will not work with the BBK in the front.
Do you think changing the fronts to a 17x9 +22 witha 5mm spacer would fit with a 265/40/17 tire?
Old Mar 29, 2010 | 02:20 PM
  #66
scotts300's Avatar
scotts300
With what brakes? I don't think I've ever seen a 265/40/17 tire though.
Old Mar 29, 2010 | 11:25 PM
  #67
QTB's Avatar
QTB
Ha, yeah sorry. After I posted that I realized that is a very uncommon size, I'd guess a 255/40/17 would be more likely.
13" Stop Techs is what I have, I'm just trying to figure out a wheel config for 17"s.
I'm thinking of that setup right now (255 front and 275 rear) with about 2.5 to 3 degs of camber up front and it should all fit and work. Hopefully it won't understeer more than I can tune out with everything else.
PS sorry if I hijacked this thread.
Old Mar 30, 2010 | 11:43 AM
  #68
scotts300's Avatar
scotts300
I'd try to borrow an RPF1 in that size first to make sure. I'm not sure how the barrel on the 9" wheel differs from the one on the 9.5" wheel. I'd think it would work, but I also thought the 9.5" would work and was surprised.
Old Mar 30, 2010 | 01:11 PM
  #69
phreaktor's Avatar
phreaktor
Design Engineer
Why not go 15"?
Old Aug 28, 2010 | 12:17 AM
  #70
KingBaby's Avatar
KingBaby
Hardest Setting
bump!
Old Oct 1, 2010 | 08:07 PM
  #71
somanymods's Avatar
somanymods
good for you
everyone on g35driver hates my 17" kosei ks-t1...well not everyone but most of them
Old May 25, 2011 | 09:12 PM
  #72
NismoZ_840's Avatar
NismoZ_840
Just added a square RPF1 17x9.5 +18 setup, running 255/40/17 Hankook RS3s. This is on a stock Nismo OEM suspension except SPL front upper arms. Tons of room in the back.
I put in a 5mm spacer (+13 effectively) and there was still a lot of room for tire or additional offset.
Still the ugly wheel gap without a drop, but this is a track setup...
There are no clearance issues on the front even at an estimated -0.8 camber, at least for a 255 wide tire. It's getting close though so have to do some testing on 265-295 to see if still clears the fender. Ataru is running 275s, but aggressive camber might be needed to clear. Here's some shots of suspension fully compressed w/ the 255 and running an estimated -0.8 camber (i.e. SPL arm w/ all three shims)...
Also, I did weigh the wheel/tire combo at 45lbs. It was 3lbs heavier than the manufacturer's claimed wheel (16lb) and tire weights (26lb).
Old May 26, 2011 | 07:23 AM
  #73
js4506's Avatar
js4506
got any pics of the whole car with them on?
Old May 26, 2011 | 09:22 AM
  #74
NismoZ_840's Avatar
NismoZ_840
Not yet, but will post one here soon...
Old Jan 2, 2012 | 05:05 AM
  #75
KingBaby's Avatar
KingBaby
Hardest Setting
bump for more nismo track setups...
Old Jan 2, 2012 | 08:51 AM
  #76
bbs350z's Avatar
bbs350z
looks great imho
Old Apr 28, 2012 | 10:15 AM
  #77
RENFRO's Avatar
RENFRO
+1000 for raw functionality. Looks sick
Old May 6, 2012 | 10:58 AM
  #78
nokimchi2's Avatar
nokimchi2
anyone else running non oem 17" setup? post up please
Old May 6, 2012 | 11:18 AM
  #79
Jairen's Avatar
Jairen
Originally Posted by Ataru074
honestly, who cares? function > form.
have you any idea on what happens to rims when you go to a road track and you use race pads like ferodo ds3000?
I don't need the car to hook up girls or to feel my wiener bigger. otherwise I wouldn't go to the track but drive a turbo 997 convertible to get some premium shallow blonde or asian.
Well said.
Old Nov 8, 2013 | 08:34 AM
  #80
dphoenix's Avatar
dphoenix
I completely agree with you!!
When it comes to racing! Go as lightweight as possible, screw for how it looks on your car. Performance and Looks dont go together most of the time.
Originally Posted by Citrus
The Nismo 380RS runs 17's up front. The Autotech Tsukada Z33 runs 17in TE37's all around. The Autobacs GT300/500 SuperGT cars run 17's. There is NOTHING wrong with 17's on a track car.
http://jdm-option.com/eng/feature/05_12/z33_v35.html
http://www.nismo.co.jp/Z-car/
Looks good OP kick some a$$!
