What size Falken FK451 with 18x7.5/18x8.5
Old Sep 17, 2003 | 10:45 AM
tyoung88's Avatar
tyoung88
Default What size tire with 18x7.5/18x8.5
Just got back from the dealer and told them no on the 18x7.5 wheels all around.
I'm thinking of ordering the Ace Zeus in Polished 18.
http://www.acealloywheel.com/abproductdetail.asp?id=15
What size Falken FK451 should I get if I have 18x7.5 wheels on the front and 18x8.5 in the back. I know there's been a lot of discussion about not differing too much from the factory setup but I'm really bad a calculating the various sizes.
I was thinking of
245/40/18 on the front
255/45/18 in the rear
Will that work? I'm such a newbie at the tire converision thing and the calculator link from the FAQ doesn't work.
Old Sep 17, 2003 | 03:46 PM
webcarconnection's Avatar
webcarconnection
Go w the 235/40 and 255/40 the 7.5 are to tight for the 245...
Old Sep 17, 2003 | 04:01 PM
tyoung88's Avatar
tyoung88
Will the above setup cause any speedo inaccuracy? Any opinions of the Ace Zeus wheels? The dealer just gave me an Ace catalog to look through and they caught my eye. Never seen a pic of a Z with them on.
Old Sep 17, 2003 | 04:12 PM
Stone Z's Avatar
Stone Z
Thumbs down
Those offsets are way too high, man.
Check out these wheels.....
https://my350z.com/forum/showthread....threadid=41942
Old Sep 17, 2003 | 04:24 PM
tyoung88's Avatar
tyoung88
well with 8.5 in the rear i can't fit 275 right? So what would be the optimal tire sizes if I have 18x7.5 in the front and 18x8.5 in the rear? Thanks so much
Old Sep 17, 2003 | 04:38 PM
Stone Z's Avatar
Stone Z
Are you dead set on those wheels? If not, you should try and get some wheels that are wider in both the front and the rear.....at least by a 1/2 inch.
Anyway, if you're gonna stick with 7.5 and 8.5 then the tire sizes you're looking at should be
225/45/18
255/40/18
Old Sep 17, 2003 | 04:42 PM
tyoung88's Avatar
tyoung88
Thanks so much Stone Z. Are you recommending wider because you think that they'll look funny or just room to grow?
With 225/45/18 and 255/40/18 will my speedo, abs, and tcs be ok?
Old Sep 17, 2003 | 04:46 PM
Stone Z's Avatar
Stone Z
Well, the offsets on the wheels you're considering aren't really Z friendly to begin with. You're gonna end up with wheels that are tucked in further than the stock rims. Secondly, the *ideal* tire size for the rear is 265/40/18 which requires at least a 9 inch wide rim in the rear.
Your speedo, abs, and tcs should be just fine.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
