Nitto NT05 Review
Old Apr 9, 2010 | 01:45 PM
  #81
BrianLG35C's Avatar
BrianLG35C
That thread is correct, but you need to look at the aspect ratio's mentioned in that thread, or maybe even do the match for yourself. A 255/275 combo with the same aspect ratio on a 13 to 22 inch wheel will not set off VDC/TCS. Yes the tires in question are taller that stock, but both the front and rear tire are taller equally, the ratio stays the same.
I hear you but I have personal experience running a 255/35/20 and had VDC issues, that's why I'm asking. 255/35/20 is a little above the 3% threshold, the VDC software will supposedly compensate for.
Geez, I'm just asking him if he's had any problem too.
Old Apr 9, 2010 | 03:40 PM
  #82
terrasmak's Avatar
And i'm just letting you know that it all depends on the rear tire that is run with the front you mention.
Old Apr 12, 2010 | 09:25 AM
  #83
Robs_350Z's Avatar
Robs_350Z
Guys, I haven't had a single problem driving normal with the VDC on. It may kick in sooner than normal if I kick the rear a little but that's hard to do with these tires. And I understand what you guys are saying with the error. Yes the ratio is larger and the width that it's taking that from is much larger then stock. Hence, there is a much larger difference in rotational velocities between front and rear. I did the math a while back and found things to be in the 3% error. I'm not much of a mechanic but I do have a decent engineering background, the math is pretty simple but don't be upset if I don't want to start writing it all over again to settle a dispute. I probably should have gone 275 in the front but wanted to be a little conservative. Now that I know where things are I'll push it next time with some body mods.
Old Apr 12, 2010 | 09:35 AM
  #84
ZRuggernDC's Avatar
ZRuggernDC
There are threads that have been raving about the NITTO NT05 since about a month after they were released. Porche, BMW, Z06 drivers all alike back this tire. And, I do as well. Great grip tire. Running mine for awhile now and they are the bomb.
Old Apr 12, 2010 | 09:38 AM
  #85
ZRuggernDC's Avatar
ZRuggernDC
I didn't realize that people even did this to be honest.
Why would you drive with your VDC on? Just curious...
I think every Z and G owner I have ever meet drives with the VDC Off.
Old Apr 22, 2010 | 09:21 AM
  #86
Robs_350Z's Avatar
Robs_350Z
Actually I agree with you. Just lazy, not beeting it and usually don't shut it off from start up.
But honestly you guys have got to try a set. Granted I'm only stock and building from the ground up ect... The traction is crazy from a 1st gear launch.
Old Apr 22, 2010 | 11:50 PM
  #87
TTRANK's Avatar
TTRANK
I don't drive with my VDC on very often but I have. I installed the KP module to turn VDC off all the time. But, I have had issues with other tires when the front/back diameter is so far off it puts the car into limp mode. This is not a problem with the sizes I run 255/35 & 275/35.
Old Apr 25, 2010 | 09:36 AM
  #88
ChinaClipper's Avatar
ChinaClipper
TTRANK, I appreciate yoru review of this tire. I am curious now that you have worn out a set of NT-05s, if you still hold true to your original statement on page one that you would buy another set? Also, having run Invos and now the NT-05s, why not move up to a set of NT-01s?????
TIA,
ChinaClipper
hulkout
Apr 28, 2017 09:00 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
nanotech
Oct 2, 2015 05:02 AM
