370Z Rays on 350Z?
Hi all I'm wondering if 370z nismo wheels fit our car without modification. Does anyone know of any 350z nismo owners who have these in their ride? I'm going to be trading my nismo wheels for them.
The wheel specs are
19x9.5 et40 255 40 19
19x10.5 et30 275 40 19
Should I be concerned about tires sizes rubbing? I'm lowered on sportline springs.
The only pics I can find are non nismo z.
Photoshop any1?
The wheel specs are
Photoshop any1?
The wheel specs are
Photoshop any1?
The wheel specs are
Photoshop any1?
Either my Google-Fu sucks, or full specifications on the 2015 NISMO 370Z wheels are just not available.
As an excited new owner of an '05 Roadster, I arranged to meet someone this weekend to buy the 2015 NISMO wheels, and did not bother to do fitment research first. Though I now suspect I'll need spacers for the front wheels to fit, having to do so will not deter me from buying them; I just wondered if anyone has any information on fitment and/or spacers and/or these wheels' offset.
Much love.
Much love.
try to put them on ?
http://www.nissanusa.com/sportscars/...versions-specs
18" x 8.0" (front) and 18" x 9.0" (rear) black-finish aluminum-alloy wheels Not Available Not Available
19" x 9.0" (front) and 19" x 10.0" (rear) RAYS® forged alloy wheels[*] Not Available Not Available
19" x 9.5" (front) and 19" x 10.5" (rear) NISMO® forged alloy wheels by RAYS®[*] Standard Standard
225/50WR18 (front) and 245/45WR18 (rear) Yokohama® ADVAN Sport® high-performance tires[*] Not Available Not Available
245/40WR19 (front) and 275/35WR19 (rear) Bridgestone® Potenza® RE050A high-performance tires[*] Not Available Not Available
245/40YR19 (front) and 285/35YR19 (rear) Bridgestone® Potenza® S001 high-performance tires[*] Standard Standard
Temporary spare tire Standard Standard
^ No, I have not tried to put them on. As stated, I will buy them this weekend.
Thanks for the link. That was the first place I looked during my search for specs. I'm particularly concerned about offset (hence my comment about spacers), and Nissan's website doesn't provide that information.
A little bit different look. They're Ray's 19x10 and 19x9 LMZ5's for the 370. Lots of folks on here seem to dislike them, but I love the way they look on a roadster. I figured it's hard to go wrong on a staggered set of Ray's 19" wheels new in the box for $800 (and that included shipping!). Now if I could just find a deal like that on a JWT TT!!! And yeah, I know it needs dropping some. I've got a set of Eibach springs on the way.
Hi guys. I got a good set of 370Z Rays for my 350Z. They are been powder coated right now to a gloss black finish.
But I have a doubt. I already studied the whole thread but can't find an answer.
Do I need a front camber kit in order to compensate the bigger (19") wheels?
In order to maintain the staggered setup and avoid any VDC issue, I'll be using 245/35R19 front and 275/35R19 rear. Also I already have 25mm spacers installed all around; maybe I'll try how they look before removing, just leaving them in fronts.
I'll appreciate your comment and thoughts.
Thanks in advance
Thanks in advance
With no information thus far on fitment of the Rays wheels from the 2015 NISMO 370Z on our 350Zs, I'll consider myself a pioneer and demand that each of you reward me with an oatmeal cookie.
The 2015 NISMO Rays wheels, as most know, are 19 X 9.5 in the front and 19 X 10.5 in the rear and are equipped with 245/40/19 and 285/35/19 tires respectively. I can confirm that they have +40 mm and +27 mm offsets front and rear.
My '05 is equipped with Brembos. Fitment of the rear wheels was issue-less, but the front wheels (though they cleared the Brembos) required 5mm spacers as they rubbed against the suspension knuckles. No hub-centric rings were needed, as the bore size of our cars is the same as the 370Z's - 66 mm. I used the 370Z's lug nuts. I don't know whether or not the 350Z's lug nuts would have worked; I didn't try.
Here are some pictures I quickly took after they were installed. The car is on factory suspension, and I see no need to lower it (famous last words). I'd be happy to provide more pictures from specific angles; just let me know.
Those rears are wide!
P.S. - I have no preference between oatmeal cranberry and oatmeal raisin.
Thanks in advance
Thanks in advance
Yesterday while trying to remove one of the rear 370Z wheels installed on my 350Z, I figured out that it can't be removed
Any one have an idea or had been through this scenario with 370z Rays installed?
I changed the 18" original wheels for the 19" nismo wheels.
The thing is that the rear wheels are not flush with the body and they looks too much out
Of the body, it is about 3/4" inches outside. I think it is due to the offset.
Is there a way to cut out anything in order to get the wheel a little more inside the body?
Nooooooooo!
i changed the 18" original wheels for the 19" nismo wheels.
of the body, it is about 3/4" inches outside. I think it is due to the offset.
