370Z Rays on 350Z?
Old Nov 14, 2010 | 06:46 PM
  #121
sharon11's Avatar
sharon11
Wow..What a lovely car!!! I like this one....
Old Nov 15, 2010 | 04:17 AM
  #122
slmdchvy05's Avatar
slmdchvy05
1500 still is a reasonable price... I paid 1400 for mine with brand new BFG Gforce tires lug nuts and already powder coated black and all I had to do is get some 20mm spacers and I was set
Old Nov 16, 2010 | 05:13 PM
  #123
Scrodes's Avatar
Scrodes
yes, but he's selling wheels only, no rubber no PC.
Like I said, not trying to troll, just trying to help the guy out.
Old Nov 18, 2010 | 07:54 AM
  #124
slmdchvy05's Avatar
slmdchvy05
1k still isn't bad considering they are 1k each from the dealer. Pc is around 200 for all the wheels, tires a good set will run you about 1k. Think about it your getting ray's. That is just my opinion I love my wheels on my car
Old Nov 24, 2010 | 10:25 PM
  #125
NISMOFO's Avatar
NISMOFO
Looks good and I like the contrast of the lugs. What size spacers are you running? Did you try fitting the front without...if so did it clear on the inside?
Old Nov 24, 2010 | 10:40 PM
  #126
angryCOWofDOOM's Avatar
angryCOWofDOOM
IMG_0036.jpg?t=1290670794IMG_0035.jpg?t=1290670755
Old Dec 1, 2010 | 05:59 PM
  #127
Scrodes's Avatar
Scrodes
Fronts wont clear without spacers - you want 20mm
Old Dec 2, 2010 | 07:38 AM
  #128
slmdchvy05's Avatar
slmdchvy05
Yea the front wheels will not clear w/o spacers, I was told that "they will clear with 15mm spacers" but I was kind of hesitant on that so I went with the 20mm bolt on hubcentric spacers and they sit really good and flush. you can also run a 25mm but IMO the 20mm hubcentric bolt on spacer is the way to go. I ordered mine from ebay and the seller's name is "OPTIONSELECTS" $75 w/free shipping, I was kind of hesitant as to buying them because I daily drive mine but I did anyways and I have been super pleased with them. I have had no issues at all "no vibrations or anything" So if you are looking for a set of spacers at a decent price I would recommend this seller only because I have them on my car.
Old Dec 2, 2010 | 07:39 AM
  #129
slmdchvy05's Avatar
slmdchvy05
Plus they have to meet DOT standards or else they would be held liable for any malfunctions, damages or anything caused by the spacers not meeting the dot standars and can be sued unless other wise stated "TRACK USE ONLY"or "OFF-ROAD USE ONLY".
Old Dec 3, 2010 | 10:04 PM
  #130
Geroy's Avatar
Geroy
sorry if i missed some other info...but 1) what do you mean that fronts wont clear w/o spacers? like what will happen, they will rub the fender or please describe the problem. and 2) since you did a 20mm spacer on a front, dont you wanna have a 20mm spacer on a back to keep the staggered ratio set up? and if you do not, then how does the car handles without a staggered set up, or shall i say modified staggered set up, since its not he same ratio anymore. thanks.
Old Dec 6, 2010 | 03:01 PM
  #131
Scrodes's Avatar
Scrodes
The inner lip of the barrel hits the suspension component (I can't remember what it is offhand without looking - but it's whatever is directly above the hub) and no you don't want 20mm rear spacers because the offset of the 370z wheels causes the rears to be flush without - if you bought 20mm spacers, then they'd stick OUT 20mms.
Trust me buddy, I wouldn't lie to ya ;-)
Old Dec 6, 2010 | 07:14 PM
  #132
Geroy's Avatar
Geroy
thanks for the info, appreciated.
i did not even think about the offset numbers, so, adding 20mm spacer to the front of 350z with the 370z 19" rays wheels will still keep the staggered set up...meaning that the track width of the front wheels will be smaller than the track width of the rear - is that correct? it sounds like, just trying to make sure we are on the same page. i am sure there is a way to calculate this sh.t using stock track width and offsets but sounds like almost easier take a tape and measure it after install. But damn, i am glad to hear that there is a need only for 1 set of spacers, those are not that cheap.
so, i also hear this mixed review of the lug nuts? still trying to figure if i should be looking for a 370z lug nuts (which for the rays wheels i believe had a washer in them) or just use my 350z lug nuts and check the torque periodically?
Old Dec 7, 2010 | 04:38 AM
  #133
slmdchvy05's Avatar
slmdchvy05
1.You have to use a spacer in the front or else the front wheels will not clear the upper suspension by the top of the wheel
2. The wheels still have the staggered offest.
3. you do have to use the 370z lugs because of the washeres on them, using anyother lug will not stay torqued down and will keep coming loose. I would advise getting the correct lugs if your going to do it.
Old Dec 7, 2010 | 09:13 AM
  #134
Geroy's Avatar
Geroy
looking for lug nuts now...any suggestions where to get or reference would be appreciated. Are these the OEM lugs nuts that 19" Rays wheels use?? (see attached)...because i see a lot of the aftermarket that say fits Rays or 370z and etc...but they do not look the same, no washer there....all are acorn
Old Dec 7, 2010 | 10:26 AM
  #135
slmdchvy05's Avatar
slmdchvy05
yes those are the factory lugs that you have to use... I will keep my eye out for some
Old Dec 7, 2010 | 12:25 PM
  #136
slmdchvy05's Avatar
slmdchvy05
FYI.... For those looking for the 370z lug nuts w/washers.....
factory 370z Lug Nut: Dorman PN# 611294
Type: Dometop Capped Nut
Thread M12-1.25
Hex Size: 21mm
Length: 38.6mm
Seat Angle: 60 Degree
Finish: Stainless
These are the OEM Lug Nuts w/washers
Here is a website that I found that sales the lugs rockauto.com and here is the Item brand and # for the lugs. DORMAN Part # 611294 they are $3.49 earch and from Jegs.com they are $52.99 for all of them, just copy and past the part number "611-294" in the search.
Link to jegs: http://www.jegs.com/i/Dorman+Product...1-294/10002/-1
link to rockauto.com: http://www.rockauto.com/catalog/raframecatalog.php click on wheel/tire then on lug nut and scroll down a few to the one with part# 611294 and there you go.
Old Dec 7, 2010 | 12:51 PM
  #137
Geroy's Avatar
Geroy
GREAT INFO on specs...unfortunately i called Jegs and they did not sh.t so they called Dorman and confirmed that $52.99 price is for package of 10. So, i guess it comes down to $106 for set of 20. But, again, great info since at least i know what type to look for, vs. i need a lug nut for 370z with rays - lol
$3.49 per lug from Rockauto might be the best deal!
Old Dec 8, 2010 | 04:25 AM
  #138
slmdchvy05's Avatar
slmdchvy05
I guess that rockauto.com would be the was to go.... You should check with a dealer to see what they charge and if you know anyone that ownes a paint&body shop or a mechanic check with them first they may get them at a cheaper price aswell.
Old Dec 8, 2010 | 05:58 AM
  #139
Geroy's Avatar
Geroy
This is just FYI for folks:
Nissan Dealer (MD): $9.61 per lug nut
Courtesyparts.com (oem parts at discount): $6.40
Dealer is marking it up 50%? unreal...
Old Dec 8, 2010 | 08:49 AM
  #140
cheshirecat79's Avatar
cheshirecat79
They've gotta make money.
