Tire pressure read
Old May 11, 2009 | 07:29 PM
tw8715's Avatar
tw8715
Default Tire pressure read
so on the tire pressure gauge..
its the top one the driver side tire pressure?
and the bottom psi reading the passenger side tire pressure?
thanks~
Old May 11, 2009 | 08:15 PM
Spike100's Avatar
Spike100
What year/model is your car?
On 2003/04 cars, you see left and right front readings, and toggle to left and right rear readings.
--Spike
Not sure. What does your manual say?
Old May 11, 2009 | 08:33 PM
SirSpeedyZ's Avatar
SirSpeedyZ
Old May 11, 2009 | 08:53 PM
Spike100's Avatar
Spike100
That's the best advice since it provides the right answer.
--Spike
Old May 13, 2009 | 12:55 AM
tw8715's Avatar
tw8715
hmm i couldnt find it in the manual.
soo since i have a 04...
top one is driver side front psi
bottom one is passenger side psi?
TOGGLE
and same for the rear?
Old May 13, 2009 | 01:49 AM
Z04's Avatar
Z04
TOGGLE
page 2-10 of owner's manual
equipped)
The tire pressure indicator shows tire pressure
(0 - 51 psi) of all wheels (except the spare tire)
by sending a signal from a sensor that is installed
in each wheel. Press the trip computer setting
switch B to change the display to F (front) or R
(rear).
doesn't specify which side
Old May 13, 2009 | 04:05 AM
ReelBigAndy's Avatar
ReelBigAndy
let 5psi out of your driver front tire, and see which reading on the gauge drops?
Old May 13, 2009 | 06:16 AM
Z04's Avatar
Z04
then again, the manual does state you shold not rely on the TPMS as a actual reading of your PSI. this means you will still need to actually use a tire pressure gauge and manually check the tires.
Old May 13, 2009 | 10:56 PM
tw8715's Avatar
tw8715
i see! thanks guys~
dont care ALOT about psi.. but just bugged me a little that the psi numbers didnt match
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
