Hey Guys, I could be wrong but I couldn't find this anywhere. I have an 06 with the 18/19 rays wheels. The stock 245/265 Bridgestone's need to be replaced and I was curious if I could put on 255/285 without any rubbing issues. I understand that adding a 10mm spacer would most likely allow for this but I dont need the extra width that bad...any input would be great! thanks.
I guess I am guilty of going for a little bit of "the look" as well as the performance. With the 10 inch wheels out back a 285 would sit nice...So you don't think I would have any issues with clearance?
I have that size on my NISMO wheels and they are exactly the same as yours. I could go wider if I wanted too as their is clearance.
After a while of having them now, I really don't like them. They look nice, but traction, and noise is terrible. MY RE050s were stickier than these were and were much quieter. I won't be buying these again.
They are starting to get louder and to the point where it's hard to hear people on the phone.
+1 on the noise. good value tires but the noise...
I'm running 295 in the back and 265 in the front on my Nismo Z.
Vredestein Ultrac Sessanta
My 285/35/19s doesn't come near to rubbing with KDW2s. Depending on the tire it probably will not rub.
Dude that did my fronts said he wouldn't do anything more than a 265. He said it was really close. One guy on here is doing a square 275 setup on a G35 I think with no problems but I wouldn't want to go that wide in the front.
I was talking about the rear. I know 275 can fit the front as my friend had that size for his race setup. I just forget the offsets. I think it was around 15~.
I would be going with Michelin PS 2 again.. PS2's do run a little wider thats what im worried about. The 285 i have now is ok, but with the nismo rears i need a wider stance
