wheel spacers advice, odd tire tize
Old May 20, 2009 | 12:27 PM
Dcdylan's Avatar
Dcdylan
Default wheel spacers advice, odd tire tize
Hey guys, I have a set of 19" Volk GT-C's 8.5" in the front and 9.5" in the rears, and the tires are 255/35/19 in the front and 275/40/19 in the rear. The offsets are +27 in the front and +24 in the rear. I'm not happy at all with the offset and want to push it out to flush, but also do not want to rub/have to roll fenders. My question is what size spacers should i use for this odd tire/wheel setup? I was thinking probably 10-15 mm in the fronts and I don't even know what to do for the rears because of the oversized sidewalls. Thanks.
Old May 20, 2009 | 01:12 PM
Thermal1's Avatar
Thermal1
Measure how much space you have between the tire and fender to move outwards. That will be how much spacer you need.
Rolling fenders is easy and probably necessary (if you are lowered...if not, wtf are you doing?). Just borrow/rent a fender roller and a heat gun
Old May 20, 2009 | 01:17 PM
Dcdylan's Avatar
Dcdylan
I'm lowered on s tech's. The body shop I usually bring it to said some bs about the fenders being really difficult to roll on the 350z =\ so that put me off wanting to roll the fenders.
How about measuring the distance between the tire and fender?
Old May 20, 2009 | 01:18 PM
Waiz's Avatar
Waiz
All depends what look you're going for.
Also, sounds like you need to go to another body shop.
Old May 20, 2009 | 02:23 PM
terrasmak's Avatar
get a roll and a pair of 10.5's for the rear. Use your old rears up front and your set.
Old May 20, 2009 | 05:51 PM
Dcdylan's Avatar
Dcdylan
i took of the wheel and did some measuring today myself with washers. 15 mm set it out nice and flush. When inspecting the fenders it was odd, it seemed like the fronts were already rolled up, whilst the rears were the opposite? Anyone else notice this? I'm guessing its to clear the fender when turning the wheels. Not sure if it will rub with this setup gonna have to buy some cheapo spacers to test it out before i get serious with some H &R's. Thanks for the advice.
P.S. I can't get 10.5 for the rears I'm way too short on cash lol. Deep dish doesn't really matter much to me as long as I can get the rubber down with the right offset.
Old May 21, 2009 | 05:18 AM
reverse's Avatar
reverse
20MM
Old May 21, 2009 | 06:33 AM
Thermal1's Avatar
Thermal1
Correct. You only need to roll the rears
Old May 21, 2009 | 06:39 AM
Entaille's Avatar
Entaille
I would go to a different bodyshop.
Old May 21, 2009 | 07:08 AM
Toby-22's Avatar
Toby-22
roll your fenders and go with either 10mm or 15mm front and back.
Old May 21, 2009 | 08:36 AM
redlude97's Avatar
redlude97
holy wack tire sizes batman!
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
