Official Aggressive Wheels & Fat Tires Thread
Old Aug 22, 2011 | 05:08 AM
  #2381
blue350zed's Avatar
blue350zed
Originally Posted by ReV2Red
That is absolute filth! I love it!
How do you like the AD08's? They seem to run a bit wider than regular 255's dont they?
Not sure how I like 'em yet. Haven't finished the build...
They do seem a bit wider than the same size Invo's I was running before.
Old Aug 22, 2011 | 06:15 AM
  #2382
VQpoweredZ's Avatar
VQpoweredZ
Brandon, looks great man. I'm with Wais on this one we need more pics
Old Aug 24, 2011 | 01:55 AM
  #2383
350Zdj's Avatar
350Zdj
sorry guys but i need advise from the Guru's in here.
I wanna go even more aggressive with my front setup.
Right now i have:
275/35 18, +25 offset. I've been losing sleep over trying to decide whether I should install 5mm spacers upfront to get an even more aggressive look. Will this rub? I did take some measurements and it looks like it is manageable but i need someone to confirm this.
Suppose I did need camber kits, how many deg I would approximately set? I'm only about an inch dropped.
thanks!!!
Old Aug 24, 2011 | 12:27 PM
  #2384
abo's Avatar
abo
hi guys, i was hoping to get some input.
current setup up:
front: 18x9 265/35/18 +22
rear: 18x10 285/35/18 +22
camber roughly 2.3 all around.
Just wondering what size spacer would look best? Thanks in advance.
Old Aug 24, 2011 | 12:53 PM
  #2385
Waiz's Avatar
Waiz
Right now i have:
thanks!!!
You should be ok with only a 5mm spacer up front but I'm sure it won't hurt to add a tad bit of camber for the front.
current setup up:
+22 is what most run, it probably "looks" fine but if you want to add a 10mm spacer max all around it would be what most people run.
Old Aug 24, 2011 | 01:17 PM
  #2386
abo's Avatar
abo
thanks for the tip. just feel like it looks a bit sunk and was considering 15mm spacers all aronud. Maybe i'll just change the wheel set up for something abit more agressive. thanks for the input tho.
Old Aug 24, 2011 | 01:22 PM
  #2387
Waiz's Avatar
Waiz
Looks are strictly personal opinion, functional-wise a +22 is pretty much ideal.
If you could post a few pics I'm sure you could get additional input.
Old Aug 25, 2011 | 12:59 AM
  #2388
350Zdj's Avatar
350Zdj
Waizz you're the man.
I'll post up pics once it's done.
Old Aug 25, 2011 | 05:21 AM
  #2389
lgear080's Avatar
lgear080
If it was up to me i'd say no spacers. especially if you're wracking
your brain over 5mm. 10-15mm and you've got my interest.
Old Aug 25, 2011 | 07:43 AM
  #2390
350Zdj's Avatar
350Zdj
That won't stick out too much? How much camber do you think i need to run if I used 10mm?
front set is: 275/35 18, +25 offset
tia bro
Old Aug 25, 2011 | 08:00 AM
  #2391
scotts300's Avatar
scotts300
tia bro
What wheel width?
Old Aug 25, 2011 | 08:47 AM
  #2392
bmccann101's Avatar
bmccann101
man, i cannot WAIT to post up in here.
Soon, tho, maybe 2 more weeks til shes done..
cars still in pieces, but.... i have a set of 325 25 20 pirellis in the back seat of the Lexus.. droppin em off at IMR in a few hours..
i do believe that will qualify me to post in the fat tires thread.
Old Aug 25, 2011 | 12:15 PM
  #2393
350Zdj's Avatar
350Zdj
Originally Posted by scotts300
What wheel width?
9.5
Old Aug 25, 2011 | 03:55 PM
  #2394
lgear080's Avatar
lgear080
i run 18x10.5 +15 up front w/ up to a 285/35/18
so i'd say you've got lots of room.
Old Aug 25, 2011 | 04:49 PM
  #2395
NA&CH's Avatar
NA&CH
A 10.5 +15 sits nice up front.
Chris
Old Aug 25, 2011 | 05:03 PM
  #2396
350Zdj's Avatar
350Zdj
awesome! thanks so much for the help guys!!
Old Aug 25, 2011 | 08:53 PM
  #2397
SE5spd's Avatar
SE5spd
im debating attempting to trade my front 9.5 rpf1 for a 10.5 front
Old Aug 25, 2011 | 11:28 PM
  #2398
Z Professional's Avatar
Z Professional
in about 2 weeks time I should have all that i need to post up in this thread.
275-35-19 on 9.5 fronts and 295-35-19 on 10.5 rears...
Dropped on Stance Gr+ true style coilovers.. and all the secondary mods that come with that.
To start off with +22 offset all around.. Just curious if I'll need to pull...I'm rolling it once i install everything but will i need to pull dependent upon how low i go?
Old Aug 27, 2011 | 01:49 PM
  #2399
sleeper400's Avatar
sleeper400
im on tein basics, 3/8" away from maxing out the front to the lowest setting. Im running rota p45r 9.5 +20 on all four corners with a square setup of 275/40. My front camber is -3.7. When i turn, I rub =( how do you guys pull this off?? Im planning on pulling the fenders to fix this
Old Aug 27, 2011 | 01:56 PM
  #2400
Duckeee's Avatar
Duckeee
thread needs more pictures and less talking
