Official Aggressive Wheels & Fat Tires Thread
Old Feb 8, 2012 | 06:11 PM
  #3021
NA&CH's Avatar
NA&CH
I think Kirbayy is prob one of the only ones doing it right. "Aggressive wheels and a Fat tire. Correct me if I am wrong. Thats aggressive and fat.
Also Lgears car is spot on as well. This is not a racing tire square setup thread. Sure you could fit a 19x11 with a +52 with a nice fat tire. But something aggressive that looks good is tougher.
Another reason this thread has only 151 pages and the stretch tires has double. They dont criticize everyone who post...
Thats my nickle
Chris
Old Feb 8, 2012 | 06:24 PM
  #3022
03threefiftyz's Avatar
03threefiftyz
Thats my nickle
Chris
There is a whole lot of criticism in that thread....
Old Feb 8, 2012 | 06:36 PM
  #3023
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
255/35R19 +18 9.5
285/35R19 +23 10.5
Old Feb 8, 2012 | 07:05 PM
  #3024
SDGenius's Avatar
SDGenius
^what are your wheel widths?
Old Feb 8, 2012 | 07:30 PM
  #3025
BEBO'S ZEE's Avatar
BEBO'S ZEE
This is probably more of a dreamer post, but...
I came across some wheels and was wondering if it would be possible to run a
18x12 +30 in the rear with a meaty tire? Would it fit flush with Rolled fenders and possibley a pull? Or would it look sunk in?
Old Feb 8, 2012 | 07:37 PM
  #3026
03threefiftyz
18x12 at +30 won't clear the front shocks on the inside. You will need to space it out.
Old Feb 8, 2012 | 07:40 PM
  #3027
jarrodh77's Avatar
jarrodh77
That's actually nearly perfect offset for fitting 12" rears without having hellastretch and 6 degrees of camber. Compared to the popular 18x10.5 +15 setup, it would EXTEND 4mm on the outside. Inner suspension clearance will be close, but should work no problem. A 315 will be slightly stretched and should fit with a good roll.
Old Feb 8, 2012 | 07:45 PM
  #3028
03threefiftyz
Scratch my post, I didn't read it through all the way. It will tight on the rear shock as well. Should be ok, though.
Old Feb 8, 2012 | 11:12 PM
  #3029
EmpireDude's Avatar
EmpireDude
9.5 10.5, sorry edited my post!
Old Feb 8, 2012 | 11:45 PM
  #3030
terrasmak's Avatar
http://www.flickr.com/photos/svillagrasa/6834717051/http://www.flickr.com/photos/svillagrasa/6834717051/ by http://www.flickr.com/people/svillagrasa/ A good pic of my 275 front and 285 rear setup on RPF1's. The wheels are 9.5+15F and 10.5 +15 rear. The corner loading almost makes the tire look stretched.
Old Feb 9, 2012 | 04:01 AM
  #3031
dkmesa350z's Avatar
dkmesa350z
Originally Posted by EmpireDude
255/35R19 +18 9.5
285/35R19 +23 10.5
ah, perfection
Old Feb 9, 2012 | 01:16 PM
  #3032
brandonz33hr's Avatar
brandonz33hr
EmpireDude, more pics now!
I'll probably be going with some RPF1s in 18x9.5 +15 front and 18x10.5 +15 rear in the near future! Im trying to decide between 245/275 40s and 255/285 35s. Im at stock height (for now) so I dont wanna create any more wheel gap! Any advice/opinions??? Thanks!
Old Feb 9, 2012 | 01:27 PM
  #3033
jarrodh77's Avatar
jarrodh77
255/275 40 will give you the exact tire diameter as stock. With a 35 series tire, you'll have shorter sidewalls than stock unless you do something like 285/315 35. Here's a good tool to play with tire sizing: http://www.miata.net/garage/tirecalc.html
Old Feb 9, 2012 | 01:30 PM
  #3034
NZMOWND's Avatar
NZMOWND
Prolly dont belong here but oh well lol
19x10 +10 255/35/19 front
19x10 +5 285/35/19 rear
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-lowness.jpg
Old Feb 9, 2012 | 02:09 PM
  #3035
AznSky's Avatar
AznSky
image1261 by SVillagrasa A good pic of my 275 front and 285 rear setup on RPF1's. The wheels are 9.5+15F and 10.5 +15 rear. The corner loading almost makes the tire look stretched.
Awesome!!! First time seeing pics of your car
Old Feb 9, 2012 | 02:30 PM
  #3036
Kirbaaybaayy's Avatar
Kirbaaybaayy
Thats my nickle
Chris
thank you! some one finally understands me haha
at least i a lot lower than some of the people and this is suppose to be aggressive set ups....
Old Feb 9, 2012 | 05:20 PM
  #3037
acke15's Avatar
acke15
Terrasmak- what's the red thing in your grill?
Old Feb 9, 2012 | 05:38 PM
  #3038
03threefiftyz
Looks like a transponder.
Old Feb 9, 2012 | 06:02 PM
  #3039
terrasmak's Avatar
245 or 255/40-18 front and 275/40-18 rear would be standard sizing. Then if you run a 35 series , you will want nothing less than a 265/35 up front and minimum of 285/35 rear.
Its a transponder
Old Feb 10, 2012 | 04:10 AM
  #3040
4SHIZZIL's Avatar
4SHIZZIL
ill be running the 305 19x10s Front Soon with the 345 19x12.0 rear (modified 370z rims)
Anyone recommend a good power steerling cooler?
when should one be conserned, if at all about cooling off the power steering system?
I have 275s fronts now.
