Official Aggressive Wheels & Fat Tires Thread
Old Mar 26, 2012 | 07:25 AM
  #3421
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by maximariceboi
Nice! whats the offset on your rears? what wheel/tire size are you running on the front? How you like the BTG kdw?
WORK Meister S1 3pc. Matte Black Step-lip
19x9.5 +24 (5mm spacer making it +19) 255/35
19x11 +32 285/35
BFG KDW tires.
LOVE the KDW tires. I'm making 420whp and they handle well, last long, and do great in the rain. Highly recommend them.
However this set-up is being replace very shortly.
Old Mar 26, 2012 | 09:03 AM
  #3422
maximariceboi's Avatar
maximariceboi
19x11 +32 285/35
BFG KDW tires.
ahh ic very nice. yea the 255/35, 285/35 has more selection. did you experience a lot of road noise with these tires? What do you plan on getting next if you dont mind me asking?
Old Mar 26, 2012 | 09:10 AM
  #3423
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Road noise is nnot a factor IMO. Between my stereo and exhaust I don't notice tire noise. LOL New wheels are HRE P43SC in Satin Black, 19x9.5 +20 & 19x11 +25 w/ Toyo R888 265/30 & 305/30.
Old Mar 26, 2012 | 01:33 PM
  #3424
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Wheels are shipping out today!!!
Front: 19x9.5 +20
Rear: 19x11 +25
Old Mar 26, 2012 | 01:45 PM
  #3425
0jiggy0's Avatar
0jiggy0
Gorgeous
Old Mar 26, 2012 | 02:43 PM
  #3426
-Trav-'s Avatar
-Trav-
Just to clarify when I mentioned road noise, it was the KDW2 I was speaking of.
Robert_K those are sick!!
Old Mar 26, 2012 | 05:42 PM
  #3427
supsam86's Avatar
supsam86
Default 5 tires? Or not?
Was stacking my track tires in the garage next to my OEM's and noticed I gained a tire! Haha! How's that for your fat tires thread?!
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-cgosms_2012-03-2608-15-11.jpg   Official Aggressive Wheels & Fat Tires Thread-20120326_201044.jpg   Official Aggressive Wheels & Fat Tires Thread-drivers-side-cropped.jpg   Official Aggressive Wheels & Fat Tires Thread-long-shot-cropped.jpg   Official Aggressive Wheels & Fat Tires Thread-hill-side-small.jpg
Old Mar 26, 2012 | 06:14 PM
  #3428
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by 0jiggy0
Gorgeous
THANKS!
Sizes & offsets?
Old Mar 26, 2012 | 06:50 PM
  #3429
supsam86's Avatar
supsam86
THANKS!
Sizes & offsets?
Front: 275/40/17 on 17X9 +24mm
Rear: 315/35/17 on 17X10.5 +28MM
Old Mar 26, 2012 | 06:57 PM
  #3430
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old Mar 27, 2012 | 04:07 AM
  #3431
4SHIZZIL's Avatar
4SHIZZIL
305s on the front test fit good!
305s drive test soon with the 275s on the rear...lol (just for the drive test)
19x10s widened to 19x12 for the 345s estimated 4-5 weeks!
Old Mar 27, 2012 | 04:14 AM
  #3432
4SHIZZIL's Avatar
4SHIZZIL
question.
the 370z rims are 19x10+30
so by adding two inches to the inside of the wheel, does that then make them
19x12+80.8
I want to double check my calculations. The face of the rim is not being touched (its outward lip to hub) demintions... however from hub to the inner part (strut) is being added two inched which is 50.8mm+
sanity check since I just pulled the trigger on this. lmao
I'll then run a 20mm spacer
19x12+60.8
Old Mar 27, 2012 | 04:38 AM
  #3433
supsam86's Avatar
supsam86
Originally Posted by 4SHIZZIL
question.
19x12+80.8
19x12+60.8
I'm pretty sure that will put you at +56mm with a 12" wide wheel. The wheel should be 2.7 inches closer to the suspension than an OEM 350z wheel...
Do you have a 370? Or a 350? I don't know about 370s, but I'm 99.9% sure this won't work on a 350. The largest tire I've seen on a 350 is a 315, and that's a tight fit with a +28 offset on a 10.5" wide wheel...
If you put 345s on the back with those wheels they would be 1.7" closer to the suspension than my 315/35's... which is impossible. I was very surprised the 315s didn't rub on the rear shock.
Even with 305s on your wheels they would be almost an inch closer to the suspension than my 315s...
Good luck with that man...
Old Mar 27, 2012 | 05:19 AM
  #3434
4SHIZZIL's Avatar
4SHIZZIL
I have a G35
I have the 370 19x10s 305/35/19 on now with a 20 mil spacer. I have at least 4.3 to 4.5 inches of room from hitting anything. so adding the two more inches is not an issue. I have my fenders rolled and I am also debating on a Slight Pull.
I know it sounds crazy but with the 305s on, the car has PLENTY of room, which is why I made the plung! Just want to make sure my offset math is right for the OUTSIDE.
the 345 will be a 345/30/19 not a 35 series, if that helps.
I really dont want to pull my fenders as of yet.
The pic is a 305/25/20 with a +25 offset. I had almost 5 inches or play with these on. So this is the rim that started me down this NO LIP, wide rim path. I could of added a 5 or 10 mil spacer easy with these too.
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-dsc_0235.jpg
Old Mar 27, 2012 | 07:19 AM
  #3435
lgear080's Avatar
lgear080
Supa... I'm running a 335 a few posts back broski
Old Mar 27, 2012 | 10:39 AM
  #3436
bbs350z's Avatar
bbs350z
^link please + specs
Old Mar 27, 2012 | 02:07 PM
  #3437
Ak48z's Avatar
Ak48z
^^ I think its on a 10.5" wheel with a +30? Super bulge
Old Mar 27, 2012 | 07:50 PM
  #3438
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... I HAVE to share these. A member on a local Houston forum posted these....
TrueForged Victory Style, 20x15 and 375 tire... Going on a '67 Camaro.
Old Mar 27, 2012 | 08:22 PM
  #3439
bbs350z's Avatar
bbs350z
^oh my lanta....
how do you guys feel about a 10.5 +11 volk on a 315/30/19 hoosier r6?
mind im on coils, stock camber, and spc toe bolts. trying to dial in my track setup. fronts are 9.5 +28 (using 25mm spacer) what front tire would you guys recommend? going for max grip possible, need obese tires
Old Mar 27, 2012 | 08:30 PM
  #3440
1991ls13's Avatar
1991ls13
