Official Aggressive Wheels & Fat Tires Thread
Old Sep 30, 2012 | 07:03 PM
  #4201
tioga's Avatar
tioga
Originally Posted by nismofreak1208
So fat wheel guru's.....I'm changing setups due to a giant nail in my sidewall of my rear re-11's so to match my MCR canards and APR wing with my v3 nismo, i'm going to go meatier. My current setup is listed below with fenders rolled, fronts pulled, and rears flared.
19x9.5 -5, 235/35/19, -2.1 camber to clear fender
19x11 -5, 265/35/19, -2.0 camber (to clear fender before it was flared out)
I was thinking of running 245/35/19 and 285/30/19 as it checks out on 1010tires.com but I wanted to see if anyone has any other suggestions. thanks
You should be fine on rear with a bit more camber.
I got my fenders rolled with camber at minus 2.5. I am pretty low too and new wheels i got are 20x11 minus7 and got 285/30 for them.. I got 255 /35 on the wheels now and with a test fit it looks like a very little pull and minus 3.5 camber will fit the 285s no problem.
Old Sep 30, 2012 | 07:10 PM
  #4202
tioga's Avatar
tioga
Originally Posted by barikalil84
Am running 295/30 19 rear but it rubs when I am backing down a drive way or going over speed bumps. I need help guys. Am going 285/35 rear I don't know if that will be better. My suspension is all stock.
Did you roll fenders in rear? Cause its crazy to imagine you are rubbing with that wheel gap
Old Sep 30, 2012 | 08:43 PM
  #4203
scotts300's Avatar
scotts300
Wheel gap has little to do with rubbing during every day excursions. Yes, his Z may be 1/2" higher than some others, but the car deflects that 1/2" at times like he is referring to.
OP - 285/35 will likely make it worse since that's a lot taller tire. Rolling the fenders would help since that buys over 1/2" of width.
Old Sep 30, 2012 | 10:40 PM
  #4204
KingBaby's Avatar
KingBaby
Hardest Setting
So fat wheel guru's.....I don't know what I want!
Well man your still gonna be mexi-flush if you don't lower to meet the tires, and flare some more...
current setup is fine if you lower a tad...
EDIT: like this
you can't half *** either of these approaches look wise, it's either you're in or out!
If you come to the fat tire side, I personally say 275/35 285/35 and raise/lower it to match along with pull/flare more!
Old Oct 1, 2012 | 05:30 PM
  #4205
big_dish's Avatar
big_dish
I've been trying to read though, but man, this thread is long. I love the fat rear tire look. Just wondering if someone can chime in with their 2 cents.
I'm not a big wheel guy. In fact, I really like the stock wheels on my 06. I painted them- and while they aren't amazingly awesome wheels by any means, I am pretty content with them. I also dont track, autox, nothing. Just a daily driver. Is there any pro/con to me getting fat rear tires? Not going for the wide wheel/tire combo, just like the look from the side. I'm a complete noob to everything wheel/tire since I usually just try to buy well rated tires. I'm literally just thinking of looks, and am unaware of performance/issues. Car sits on Eibach pro-kit springs also.
<a href="http://photobucket.com" target="_blank"><img src="http://i11.photobucket.com/albums/a154/big_dish/doorhandle2.png" border="0" alt="Photobucket"></a>
Old Oct 1, 2012 | 05:53 PM
  #4206
805350z's Avatar
805350z
^ dat paint! Stick to your oem sizes. A high quality tire will get you further than a wider one in your situation.
Old Oct 2, 2012 | 09:36 AM
  #4207
Godlyg's Avatar
Godlyg
subd
Old Oct 2, 2012 | 09:39 AM
  #4208
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Snapped this before returning it back to PowerFab. Maybe one day I'll get to enjoy it at 100%!
Old Oct 2, 2012 | 09:48 AM
  #4209
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I say run a 255/40 (F) & 275/40(R) (same circumference as OEM) or a 285/40 (R).
Old Oct 2, 2012 | 03:16 PM
  #4210
-Trav-'s Avatar
-Trav-
You only care about how it looks from the side? If thats the case I see no point in going wider. Tires will be more expensive and well, you cant tell the difference from a profile view. Just stick to what you have.
Old Oct 2, 2012 | 04:24 PM
  #4211
terrasmak's Avatar
Oh dam, so nice.
Old Oct 2, 2012 | 07:35 PM
  #4212
big_dish's Avatar
big_dish
Cool, thanks. I'll see if those sizes are what I'm talking about. Dig those wheels by the way.
Thanks guys, I appreciate it, although I think you missed an important part of my post. I'm NOT looking to go wider, I just like the fatter tire from the sidewall view. Although, like I said, total "specialty" tire noob, so I don't know if thats mutually exclusive and I can have a "fat" tire from the side without needing a wider wheel/tire combo.
Old Oct 2, 2012 | 07:40 PM
  #4213
-Trav-'s Avatar
-Trav-
So you want a "bubbly" looking tire I suppose? The stock tires are pretty damn bulgy as is. If you wanted you could do 255/45 in the rear and 245/45 in the front. The 255/45 is taller than a 245/45, and your front tire would look almost identical to the rear tire you have now. Is that what youre after?
Old Oct 3, 2012 | 10:29 AM
  #4214
big_dish's Avatar
big_dish
I tried to find a photo but failed... I know I have seen a silver/grey Z on here that has exactly what I am talking about.
Anyway, yeah I thinking of same size front tire, but a taller sidewall rear- I just think it looks a bit more aggressive than the standard tire size. I'm honestly not sure if what I am looking for is a ridiculous thought or realistic. haha
Wouldnt a 255 just be a bit wider? Or is the aspect ratio of the sidewall taller/thicker from rim to wheel well?
Old Oct 3, 2012 | 05:22 PM
  #4215
-Trav-'s Avatar
-Trav-
A 255/45 would be slightly taller than a 245/45. A 245/50 would be a full inch taller.
Some pics for reference, both on an 18x8.5" wheel:
245/50 -
255/45-
Old Oct 3, 2012 | 05:40 PM
  #4216
K350Z52's Avatar
K350Z52
Here is mine
I know there are Varrstoen haters but whatever lol
Varrstoen 2.2.2 19" +12 offset
front: 9.5 255/40/19
Rear: 10.5 305/30/19
Pics time
Attached Thumbnails Official Aggressive Wheels &amp; Fat Tires Thread-fat.jpg   Official Aggressive Wheels &amp; Fat Tires Thread-fatt.jpg   Official Aggressive Wheels &amp; Fat Tires Thread-supafat.jpg   Official Aggressive Wheels &amp; Fat Tires Thread-fattt.jpg
Old Oct 3, 2012 | 06:06 PM
  #4217
Ztouring04's Avatar
Ztouring04
^ very nice I'm on a 295/35 with a 18x10.5 +15. Next tires I thinking I'm going 305/30
Old Oct 3, 2012 | 07:04 PM
  #4218
K350Z52's Avatar
K350Z52
Thank you i like it a lot! haha
Old Oct 3, 2012 | 07:17 PM
  #4219
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I think that +12 looks too bow-legged out. Love the 305.
Old Oct 3, 2012 | 07:58 PM
  #4220
solidsnake's Avatar
solidsnake
Rk that garage was made for your ride. I love the tire tread. So jelous!
