Official Aggressive Wheels & Fat Tires Thread
Just wanted to run this by the forum before I did anything crazy. Thinking of going with 19x9.5 +28 in front with 255/35/19 and 19x11.5 +10 with 305/30/19 in the rear and considering either Stance Pro Comp coilovers or a set of Tanabe Sustec Pro 5's. And of course fender rolling and a pull, not sure how far out the fenders will need to be pulled though. Opinions, fitment issues? I'm new to this but I think I got it down.
Hmmm and here I thought I had it figured out, ****. >.<
Roll and pull and ur good dude u will just have to pull a little more. I have 19x10.5 +12 offset with 305/30 in the rear and i need to pull a little more a slight pull and slight roll fixed the problem for me but since imma drop some, imma have to get a decent pull and a tight roll
hey I was wondering how low did you bring down the rear?? We have the same suspension setup (KW V3 w/ all SPL arms).. my rear is down as low as possible but I wanna see whats the widest I could fit without pulling the fenders would probably rather lift it a bit.. I have the 285-30's on there now with plenty of room and want widdddeeeerrrrrr haha
Finally, after a year owning these the fronts are ready to be replaced on my Rays Nismo, current running 285/35/19 in the rear and 245/40/18 in the front. I was thinking of going 265/40, but is 275/40 pushing it for 9in?
275/35 will work great up front with those wheels
ummm no. I run a 305 rear on +18 10.5 and I scrub all over with a good roll and stock camber settings(what are wide tires good for if you run retard camber). Anyway, pushing them out 20mm more is going to make it impossible without major work.
Also, I run michelins which seem to have a more square shoulder compared to say hankook or vredestein. Having to install +10mm fenders to get my wheels to fit.
The 19x11.5's only sit out 13mm each way further than a 10.5. I have at least 3/4" clearance on the inside and with the 305's another 13mm wouldnt be that big of an issue as the stretch will provide a bit more clearance than my set up. If in doubt do a slight pull in the affected area
Yes. The sidewall will be around the same height as your 245/40's.
11" +25 would be nice! Stoptech brake clearance is an issue. My GT-S barely clear now.
