Official Aggressive Wheels & Fat Tires Thread
Old Nov 3, 2012 | 01:17 PM
  #4301
STL 350Z's Avatar
STL 350Z
Someone needs to save this thread. It's turning into sh*t.
Old Nov 3, 2012 | 01:42 PM
  #4302
KingBaby's Avatar
KingBaby
Hardest Setting
Only the lord knows that I'm doing the responsible thing right now, delay all my plans by months!
That Nismo decal is retarded!
Old Nov 3, 2012 | 02:15 PM
  #4303
Waiz's Avatar
Waiz
That setup does not belong in this thread, not even remotely aggressive enough
Old Nov 3, 2012 | 02:20 PM
  #4304
STL 350Z's Avatar
STL 350Z
I call for a removal!!!! lol
Old Nov 3, 2012 | 02:41 PM
  #4305
SR71's Avatar
SR71
Lead Super Moderator
Seconded.
All in favor........
Old Nov 3, 2012 | 03:01 PM
  #4306
ZS14RR's Avatar
ZS14RR
Originally Posted by Robert_K
305/30-19 R888 ftw!
fuking sick!
Old Nov 3, 2012 | 04:50 PM
  #4307
-Trav-'s Avatar
-Trav-
In an attempt to save this page (and the thread) I'd like to post my 2 favorite fat & aggressive setups of all time:
resauto:
HRE 543
19x9 -16 255 30 Conti sport
19x11 -3 315 25 Conti sport
Toby-22:
19x9.5 +12 275/30/19
19x10.5 +7 305/30/19
Old Nov 3, 2012 | 05:01 PM
  #4308
KingBaby's Avatar
KingBaby
Hardest Setting
Nice tribute post
Old Nov 3, 2012 | 06:07 PM
  #4309
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Isn't Scott's 350Z N/A and I believe he run a 305 or 315 square set-up! So 245 on the front...
Old Nov 3, 2012 | 06:25 PM
  #4310
SE5spd's Avatar
SE5spd
Someone wants to trade my 9.5 rpf1 front for his front 10.5 rpf1 so I may be running 10.5 square
Only problem is I already have tires garaged (275/285) so I may sell the 275 and be 285 square. Hopefully it all works out and I get these 10.5 front.
Old Nov 3, 2012 | 06:28 PM
  #4311
SE5spd's Avatar
SE5spd
Scott has ran 305 square. Mike is crazy, he runs 315 A6 square on 18x10.5 +15 RPF1
Old Nov 3, 2012 | 06:42 PM
  #4312
terrasmak's Avatar
The 275's will work just fine on the 10.5 inch wheels. Just wear them out and go 285 later.
Old Nov 3, 2012 | 06:43 PM
  #4313
03threefiftyz's Avatar
03threefiftyz
315's tuck just fine on 99% stock fenders...
Old Nov 6, 2012 | 06:34 PM
  #4314
terrasmak's Avatar
285/35-18 front and rear, fronts are on 10.5 Enkei NT03 spaced to +20 and the rears are on 10.5 +15 RPF1
http://www.flickr.com/photos/61208532@N05/8162983913/http://www.flickr.com/photos/61208532@N05/8162983913/ by http://www.flickr.com/people/61208532@N05/, on Flickr
http://www.flickr.com/photos/61208532@N05/8162967030/http://www.flickr.com/photos/61208532@N05/8162967030/ by http://www.flickr.com/people/61208532@N05/
I have some wheels to sell, then i will have matching sets of 10.5's front and rear.
Old Nov 6, 2012 | 07:45 PM
  #4315
-Trav-'s Avatar
-Trav-
Nice n chunky
Old Nov 11, 2012 | 01:36 AM
  #4316
taryon's Avatar
taryon
Could anyone tell me if everything will be fine with 285/35 on 18x10 +25s in fronts?
Old Nov 11, 2012 | 01:59 AM
  #4317
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I think someone has ran a similar set-up but I don't recall the wheel width and offset.
Suspension clearance: Package 2 is 25 mm (1'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers.
Fenders clearance: Package 2 will stick out 35 mm (1.4'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwell clearance: The same.
SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 59.8mph (96.3km/h): 0.3% slower.
Edit: Check out post #4314. LOL!!!!
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-screen-shot-2012-11-11-at-1.57.09-pm.png
Old Nov 11, 2012 | 02:05 AM
  #4318
taryon's Avatar
taryon
The thing is that in the 4314 setup, its got +20 offset compared to my +25 and its a 10.5 width wheel
Old Nov 11, 2012 | 04:03 AM
  #4319
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... You're set-up will sit 5mm closer to the suspension.
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-screen-shot-2012-11-11-at-4.03.25-pm.png
Old Nov 11, 2012 | 07:40 AM
  #4320
terrasmak's Avatar
Comparing my specs vs yours, will fit no problem at all. You will even be able to run less camber if you want.
I run 10.5 +20 up front with 285's.
