Official Aggressive Wheels & Fat Tires Thread
Old Jun 28, 2013 | 06:07 PM
  #4841
herrschaft's Avatar
herrschaft
Originally Posted by STL 350Z
If they dont fit right they'll be in the marketplace LOL!
They'll fit, I have 275/30 on a 19x9.
Old Jun 28, 2013 | 06:16 PM
  #4842
-Trav-'s Avatar
-Trav-
275 is definitely not stretched on a 9.5....
I was comparing the amount of stretch to that of a 305 on a 10.5, which would bulge more than the 275/9.5. Im only speaking of a 30 aspect. The tire brand will be a huge factor as well. I guess the term "stretch" is subjective when dealing with normal fitting tires. To me if the lip protector isn't touching the lip itself then its beginning to stretch.
Dunlop dz101 275/30 on a 9.5, known for running narrow:
Other end of the spectrum. Pirelli PZero Rosso, a much better fit:
There are other brands that run even more narrow/wide. Can't speak on the Invos though, never seen one mounted in that size.
Old Jun 28, 2013 | 06:36 PM
  #4843
STL 350Z's Avatar
STL 350Z
Hows it look? Can you post pics?
Old Jun 28, 2013 | 07:17 PM
  #4844
herrschaft's Avatar
herrschaft
Yokohama AD08, 275/30/19
Old Jun 28, 2013 | 07:24 PM
  #4845
mr. sparco's Avatar
mr. sparco
http://www.tirerack.com/tires/tirete...jsp?techid=149
Sometimes the tire sidewall raised/protector design gives you a false stretched look. Various side wall designs will make the tire either look fat or stretched without actually being one or the other.
Old Jun 28, 2013 | 07:36 PM
  #4846
-Trav-'s Avatar
-Trav-
Definitely true, and the camera angles can also be deceptive. That pic of the direzzas look to be unquestionably stretched with that angled sidewall.
Regardless, I wasnt trying to say "275/30 will stretch on a 9.5", rather the 305 will bulge more on a 10.5 than a 275 would on a 9.5. The 10.5 wheel is 26.4 mm wider than the 9.5 yet the tire is 30mm wider, so the 305 will be 2.2mm wider on each side of the rim.
That yoko fit looks superb.
Old Jun 29, 2013 | 05:02 AM
  #4847
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Damn. Already ordered the 265's after seeing Rober K's setup of 305/30 rear and 265/30 fronts. His setup looks great.
Thanks. Remember the R888 run big so a 265 R888 looks larger
Old Jun 29, 2013 | 07:19 AM
  #4848
ProXR 440's Avatar
ProXR 440
They'll definately fit. It's up to you if you like the way they look or not. If you don't like them DT will probably just order you another size. If they say you're stuck with them I'd find another DT to deal with. The 275's will bulge just slightly more on a 9" wheel than your 305's will on a 10.5" wheel. Will you be able to tell? Maybe maybe not. It's only about 8mm and your sidewall heights are different from front to rear.
Old Jun 29, 2013 | 07:33 AM
  #4849
STL 350Z's Avatar
STL 350Z
If there isnt a noticable difference in size I will be ok. Not sure why Concept One did the size like they did. Makes tire buying difficult.
Will the sidewal hieght look stupid? What would have been a better size to have gone with (275/35?) for future reference. And where is that calulator from?
Old Jun 29, 2013 | 08:11 AM
  #4850
ProXR 440's Avatar
ProXR 440
Go to post #4807 and I posted the link and pics of my car there. Sidewall height of the 275/30 is a perfect match for your 305/30. A 9.5" front wheel would make it look better. Unless you're super picky which it doesn't sound like you are you'll be fine. I would of been torn between the 275/30 or 255/35 with your rear setup.
Old Jun 29, 2013 | 08:26 AM
  #4851
mr. sparco's Avatar
mr. sparco
I have 275/30s on 19x10.
Old Jun 29, 2013 | 09:00 AM
  #4852
STL 350Z's Avatar
STL 350Z
I'm not super super picky but thanks so much for the help!
By the way that looks on a 10in I will be more than ok on a 9in. Thanks for posting the pic!
Old Jun 29, 2013 | 09:15 AM
  #4853
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Toyo R888 265/30-19x9.5 +20
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-img_0341.jpg   Official Aggressive Wheels & Fat Tires Thread-620505_392229267497309_1951881467_o.jpg   Official Aggressive Wheels & Fat Tires Thread-img_0011.jpg
Old Jun 29, 2013 | 10:10 AM
  #4854
mr. sparco's Avatar
mr. sparco
Forgot I used to have 275/40s on 18x9 (rear) back in 2006.
Old Jul 3, 2013 | 12:39 PM
  #4855
zdaddy2008's Avatar
zdaddy2008
19x9.5 +20 with 275/30 front. 19x11 +18 with 305/30 rear. Enjoy!
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-p1030154.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030156.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030159.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030160.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030162.jpg
Official Aggressive Wheels & Fat Tires Thread-p1030177.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030178.jpg   Official Aggressive Wheels & Fat Tires Thread-p1030182.jpg
Old Jul 3, 2013 | 12:58 PM
  #4856
STL 350Z's Avatar
STL 350Z
That looks amazing!^^^^^^^^
Old Jul 5, 2013 | 02:25 PM
  #4857
NA&CH's Avatar
NA&CH
19 x 10 +25 square. I am going to run 275-30-19 front and 305-30-19 rear. Thoughts???
Chris(back to gold)
Old Jul 5, 2013 | 04:54 PM
  #4858
mr. sparco's Avatar
mr. sparco
Nice, can't wait to see the new 19" setup.
Old Jul 5, 2013 | 04:56 PM
  #4859
STL 350Z's Avatar
STL 350Z
Chris(back to gold)
I say go for it!
Old Jul 5, 2013 | 05:53 PM
  #4860
terrasmak's Avatar
Chris(back to gold)
Thinking 275/30 front and 275/35 rear would be killer
