Yeah, it looks off in some lighting but in the perfect light it's just again, this isn't the final setup. SPC toe bolts are on the way to fix toe and raise the rear some so it's stops rubbing but it does fit
Hey guys, I'm not on here often but if finally got my new wheels on and decided to join the band bagon. What you see isn't the final product yet, need to raise the rear some and adjust toe and it's done. They're 19 inch Work VS-XX. 305/30/19 front - 325/30/19 rear
Yeah, again not final setup. Shops light turned off in the middle of alignment so had to leave haha. Just showing you guys how it is so far.
That's a beautiful set of wheels, but you went WTFB on the tire sizes, IMO, for the wheel sizes. Are they 11" +13 front and 12" +13 rear? If not, what are the wheels widths and offsets? If you dial in the look with camber, be prepared to buy new tires again soon from regular street driving.
I agree with this. I love the look you are going for but with tires that wide it's just not looking right so far. Like scott said if you run enough camber to fit those tires under your fender you will be going through tires quite a bit. In my opinion you will need much smaller tires to have a bit of stretch.
With the tire physically sitting outside the fender it doesn't look very good at all.
The wheels under the fender but it's rubbing in the rear so I'm raising the rear this weekend and installing new toe bolts. May raise the front as well but so far no rub in the front. Again, this isn't the finally setup by a longshot.
Good luck!
ps - I'd put that 305 in the back, and grab a 285 for the front!
