Official Aggressive Wheels & Fat Tires Thread
Old Mar 15, 2012 | 01:08 PM
  #3281
SoCal07HR's Avatar
SoCal07HR
Originally Posted by myzproject
Got my rims coming in and need a little advice on the tire sizes to get.
rims are
19x9.5 +20 front
19x11 +18 rear
I'm lowered on tanabe gf210's and fenders are rolled. Was thinking of this tire setup
255/35/19 fronts
295/30/19 rears
Any advice if I will have trouble with my rears rubbing or should I go with a 285/35/19 for the rear and keep the 255/35/19 front? Open to suggestions here.
275/30 front and 295/30 rear. If youre not afraid to run a bit of rear camber and roll and pull a bit go with 305/30 rear.
Old Mar 15, 2012 | 02:02 PM
  #3282
Bmurray350z's Avatar
Bmurray350z
What size tires would be best for 18x10 +25 all around? Lowered on tanabe gf210's and fenders are NOT rolled. Do not want any stretch at all.
Edit- does 265/35 all around sound about right? rotating tires would be a plus.
Old Mar 15, 2012 | 03:53 PM
  #3283
terrasmak's Avatar
285/35 all around is proper for this thread. It will work too.
Old Mar 15, 2012 | 04:03 PM
  #3284
r_seng's Avatar
r_seng
Bent and chipped my passenger side front fender a few days ago entering a driveway.
Old Mar 15, 2012 | 04:19 PM
  #3285
350zfan1's Avatar
350zfan1
In serious need of help with tire size so i can ditch the hard park gayness stretch look ad be functional with my new JWT TT.
New wheels are re30's 19x10 and 19x11 out back unfortunetly no clue on offset.
Dropped on eibach pro kit springs and konis.
Roughly an inch lower than stock.
Whats the biggest set of R888's i could run front and rear...?
Old Mar 15, 2012 | 04:53 PM
  #3286
-Trav-'s Avatar
-Trav-
Depends on offset and how much camber youre willing to run. Based on widths alone, 275/305 30 sounds good. If you were sporting the "hard park gayness stretch look" before then you prob have aggressive offsets, in which case you might have to go a size down in tire.
Still need offsets though.
Old Mar 15, 2012 | 04:55 PM
  #3287
-Trav-'s Avatar
-Trav-
Front tire/wheel size, camber and how low?
Old Mar 15, 2012 | 06:04 PM
  #3288
SE5spd's Avatar
SE5spd
265 will have a slight stretch on a 10" rim
Old Mar 15, 2012 | 07:17 PM
  #3289
Bmurray350z
275/35 wouldnt work up front without a roll either, would it..
Old Mar 15, 2012 | 07:24 PM
  #3290
SE5spd's Avatar
SE5spd
you cant roll an already roll fender, Zs come rolled from the factory up front..
Old Mar 15, 2012 | 07:31 PM
  #3291
Bmurray350z
oh. shows how much i know about this stuff. well in that case, would a pull be needed for the 275/35?
Old Mar 15, 2012 | 07:46 PM
  #3292
SE5spd's Avatar
SE5spd
just some camber
Old Mar 15, 2012 | 07:50 PM
  #3293
Bmurray350z
just some camber
Stock front suspension?
Old Mar 15, 2012 | 07:57 PM
  #3294
SE5spd's Avatar
SE5spd
I got stock front arms too, im on 265s though and I dont rub or anything.
Old Mar 15, 2012 | 08:01 PM
  #3295
Bmurray350z
So you're running 265 on what size wheel, and stock front suspension as well? Thanks for babying me through this. Might need to take to pm's
Old Mar 15, 2012 | 08:12 PM
  #3296
SE5spd's Avatar
SE5spd
pm'd you
Old Mar 15, 2012 | 08:43 PM
  #3297
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm currently on Hotchkis Spring with 19x9.5 +19 & 19x11 +34 WORK Meisters and running 255/35 & 285/35 BFG KDW. I'm waiting on delivery of HRE P43SC 19x9.5 +20 & 19x11 +25 and will be running R888 265/30 & 305/30's. Looking to get the KW V3 coilovers. JWT 700BB kit & built long block as well. Some suggested the 275's but the R888's run big. Hope this helps.
Old Mar 15, 2012 | 08:51 PM
  #3298
805350z's Avatar
805350z
18x9.75 +20 with a 275/35 up front SLIGHT camber and roll. no stretch at all. If you go with a 285 make sure you get a decent tire company or else you will end up getting mad oversteer.
Old Mar 15, 2012 | 09:19 PM
  #3299
SoCal07HR's Avatar
SoCal07HR
I'm running the same size and offset wheel up front with -2 degrees camber and a 275/35. Stock fender, no roll. By looking at mine I could have gone with a 285/35 front easily. I have pics I couple pages back.
Old Mar 15, 2012 | 09:36 PM
  #3300
SoCal07HR's Avatar
SoCal07HR
I'll take a good pic of the front fitment for you tomorrow too. I figure it's a good chance to *****.
