Official Aggressive Wheels & Fat Tires Thread
Old Mar 9, 2017 | 08:49 AM
  #5781
bmccann101's Avatar
bmccann101
Congratulations on Internet nit picking the camber. It's - 3.5.. Factory is right at - 1.8-2.0...not that big a deal.. But for all that effort, no one notices that the car is aired out flat in my garage.. Slow clap guys. Slow Clap.
sometimes I end up back in old threads.. and I see old posts.. and I wonder wtf I was doing or dealing with that day lol. smh.
It gets real fun when I go WAY back and see old posts I made before I had proper PT for my back.. my "on pain meds" posts are even weirder lol.
Such is life.
Old Mar 17, 2017 | 06:45 PM
  #5782
fishclub's Avatar
fishclub
275/285 combo on ssr gtx01
Old Mar 23, 2017 | 06:11 PM
  #5783
fishclub's Avatar
fishclub
Old May 26, 2017 | 04:26 PM
  #5784
sage_lee's Avatar
sage_lee
275/35/19 on 19x11"
I know theyre slightly stretched, but I'm putting on 285's next week, and after a wash I couldn't resist.
Old May 27, 2017 | 04:32 AM
  #5785
craig12895's Avatar
craig12895
That is more than a slight stretch. And it definitely won't please the guys in this thread. Im running a 285 on a 19x9.5
Old May 27, 2017 | 09:06 AM
  #5786
sage_lee's Avatar
sage_lee
You think? in the first post it said 275's and 10.5's. only a little bigger wheel. Oh well I'm getting 285's next week.
thats some meat ^^
Old Jun 5, 2017 | 06:13 PM
  #5787
kenp60's Avatar
kenp60
Default Going to 305/30/19
Here is what is strange, I hear about having to go with additional camber and rolling with 305/30/19s. Right now I am sitting with 295/35/18s with Tein S tech lowering springs in addition to an Energy Suspension polyurethane spring perch which is a good half an inch narrower than the stock spring perch and look at the gap I still have. At this point I don't think I should be worried about rolling an camber at this point. My new wheels are going to be 25mm offset as apposed to 27mm I have now. Should I be worried about this fitment? BTW fronts will be 9.5 22 mm 275/30/19
Current setup 295/35/18
New setup 305/30/19 and 275/30/19 front
Old Jun 5, 2017 | 06:19 PM
  #5788
kenp60's Avatar
kenp60
BTW, these TSW Portier's 18x10.5 and 18x8.5 with Nitto NT05s 295/35/18 and 245/40/18 with less than 4000 miles will be up for sale soon if you are interested.
Old Jun 5, 2017 | 09:17 PM
  #5789
MicVelo's Avatar
350Z/370Z Tech Moderator
I'm trying to decipher exactly what the mystery is here. You've mixed heights, widths, offsets into a single question here, only one of which has anything to do with your primary concern, wheel gap. At least I think that's the question you're raising.... So, here's the 411 on the wheel gap...
Here's stock (stock 17s or 18/19 Nismo, don't matter. Rolling diameters are within fractions of the 18s shown):
Size............Rolling Diameter (in.)
225 45% 18 25.97 Stock Front Reference Size
245 45% 18 26.68 Stock Rear Reference Size
Here's your sizes:
Current (?)
Unknown front size
295 35% 18 26.13 Rear -0.55" delta
Where you're headed:
275 30% 19 25.50F -0.47" delta
305 30% 19 26.20R -0.48" delta
Of course there's going to be a gap.
And how exactly does a "narrower" spring perch factor into this? What purpose does it serve? Narrower spring set? Methinks you mean "thinner", yes? (As in flatter with spring sitting lower, right?)
In any event, good luck with those size tires; particularly getting them up to optimum running temperature where they'll be capable of doing their jobs.
Old Jun 6, 2017 | 07:50 PM
  #5790
kenp60's Avatar
kenp60
Thanks for taking the time to reply, what you said makes sense. I spent quite a bit of time and research to make sure my new setup didn't upset the VDC so of course my gap is pretty much going to be the same. My rear spring perch mod did help me level out the ride to about 1 inch in the rear which is what I was shooting for. Bottom line is that I didn't want to have to roll the rear fenders with my new setup. For now this is a daily driver and it looks like I won't have to. As far as warming up these fat tires, well, summers in my neighborhood hovers between 90 to 100 degrees with high humidity. I live in a mountain valley and will travel about 45 minutes in curves and hairpin curves before I get to a straight stretch of road, which is precisely why I have spent more on suspension and tires over engine mods at this point for my application, so far I'm super happy with the returns on my investment. I truly appreciate you insight as you clearly know your stuff, and that is why I spend time in these forums before I pull the trigger on some of these upgrades.
Old Jun 15, 2017 | 02:10 PM
  #5791
bmccann101's Avatar
bmccann101
12 -7 and 14 -78
She will probably push a bit, but we shall see. I didn't use a stupid wide tire out back, so maybe not too bad
finally got all the air bag nonsense removed .. back to static w fortune Auto, swift and voodo13 gear.
Car hasn't been aligned yet, but we did as best we could to eyeball it and at least keep it even side to side.. will make aligning it easier soon. By looking at it, id imagine I'm still a hair more than factory camber here.. but not for long.
Will start with factory spec camber and toe in the rear, perhaps a hair less camber than factory spec.. low side if anything..
Front will keep some camber, and we will play w the caster a hair to see what tire wear and contact is like up front under use.
Since the flares need to rebuilt to fit the wheel and tire combo anyway/.. might as well align it, drive it a bit, get it set up where it feels good, and then see where the camber and whatnot is at, and THEN finish the fiberglass work to fit the tire.
I am SO fkn excited to have this thing huck-able again... you have no idea.
I miss having a non fragile car , w mods, more is not always better. #nomohardpark
Old Jun 15, 2017 | 03:47 PM
  #5792
sage_lee's Avatar
sage_lee
295 325
12 -7 and 14 -78
I think I just came.
Old Jun 18, 2017 | 05:57 PM
  #5793
G4nismo's Avatar
G4nismo
275 rear. Hankook ventus evos
Old Jun 23, 2017 | 08:44 PM
  #5794
Ruiner54's Avatar
Ruiner54
I run 18 by 12 rear with 330s and front are 18 by 10 with 305s
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-17148921_10212108669133491_1456553067_o.jpg
Old Jun 24, 2017 | 12:54 PM
  #5795
Green's Avatar
Green
What wing is this??
Old Jul 1, 2017 | 08:50 AM
  #5796
sofakiing's Avatar
sofakiing
Originally Posted by Green
What wing is this??
Garage Mak
18x10.5 , 275's...i think
Old Jul 20, 2017 | 05:20 PM
  #5797
Manny00's Avatar
Manny00
18x10.5+15 square
275/35 Front, 285/35 Rear.
Old Jan 8, 2018 | 04:51 AM
  #5798
craig12895's Avatar
craig12895
Bumping this thread with possibly the widest tire ever put on a stock body Z (meaning fenders are pulled but no flares/widebody).
Car is still aired up but when lowered it'll fit perfectly.
Final sizes are 19x8.5 +11 and 19x11.5 +45
Old Jul 9, 2018 | 02:00 PM
  #5799
bmccann101's Avatar
bmccann101
Moving fwd slowly but surely..
Should be mostly done by the end of this summer...
Quick render of what the final will end up as :
Old Sep 12, 2018 | 12:19 PM
  #5800
eddielujan's Avatar
eddielujan
☝️ Damn!! Insta?
