Official Aggressive Wheels & Fat Tires Thread
Have an 04 Touring garage queen. It's time for tires, so I've decided to go with new wheel and tires. I need some help from the experts. Can someone give me a recomendation on wheel and tire sizes without rolloing the fenders. I was leaning towards 245/35 and 275/35. Can I go larger? What offset will I need? Can I do it without spacers? Thanks in advance.
If you want excessive and have people say "wow, that's a lot of tire-how-did-you-do-that?" get 285/30/18s for all four. Plus you'll balance out the understeer of the car, give yourself rotateability (that's a funny word), and be ready IF you ever want to do any spirited driving / competing.
Otherwise, I think the 265/295 set will work ok depending on if the tire runs wide and how the shoulders are designed. It's the 295 rear I'm worried about, as I have never seen a really good fender roll so I have avoided them like anthrax on tampax.
Thereforrrrrrrrreee, If you running a 9.5 +20 square. Then you've got a 5mm spacer bringing you to +15 square...
My 18x10 +15 should only stick out 6.4mm more than yours on the outside/inside according to my Tire Stretch Calculator....assuming pad thickness of the two different wheels are the same? Either way thats basically 1/4". I'm liking the 265/35 - 295/35. THREE questions for you....
Does that set up mess with VDC? And, did you roll AND pull the rear, or just a full rolling? WHAT ARE U DROPPED ON IF ANY?
WHEEL REFERENCE ONLY...LOOK AWAY FROM THE STRETCHED TIRE:
This is the size/offset I'm using...
<a href="http://www.flickr.com/photos/dvarnell350/5264426713/" title="grids 2 by dvarnell350, on Flickr"><img src="http://farm6.static.flickr.com/5169/5264426713_f83824c2aa.jpg" width="500" height="375" alt="grids 2" /></a>
Yes Rotas (for now). I left the fronts alone - the rear i did pull ever so slightly - nothing too big or noticeable and mainly because i coincidently did it on one side when i first started.
My car was an enthusiast model and only came with tcs no vdc and i usually keep it off so no issues there. And i'm lowered just shy of an inch on teins. maybe like 19-20 mm.
I'm not sure I understand the function of this wheel and tire set-up. Could you elaborate? I ask because you didn't need an 11" front wheel for a 265 tire, nor a 12.5" wheel for the 315 and it looks like you fubar'd you panels trying to make them fit. Going for the stretched / poke look while trying to keep a big foot print?
BTW, where is the torque wrench?
ccdan thanks ive been emailing ccw checkin out the honda ccw thread and asking countless members for a setup similar to this and the pictures answered my question thanks,well..........not all my questions...you got pm!
anyone running 10.5 up front?
im running 18x10s on all 4s without problems. However i may have found me some extra wheels. 18x10.5s on all 4s. Thinking maybe a 265/40 F and 295/35 R. Idk though. My coils are coming in soon i guess and im kinda scetched out about rubbing
