Official Aggressive Wheels & Fat Tires Thread
Old Jan 6, 2011 | 02:11 PM
  #1461
NA&CH's Avatar
NA&CH
Just got a great deal on some 265-295. Putting them on my 18.9.5 +20 Folks te-37. I have a eibach drop I am planning on rolling the rear do yu guys think I can add some spacers? I'll post pics next week!
Chris
Old Jan 6, 2011 | 02:37 PM
  #1462
scotts300's Avatar
scotts300
Originally Posted by nismonian
question for you wheel guru's here.. what would be the recommended setup on 18x9 front and 18x10 rear 275/35f and 285/35r or 265/35f and 285/35r?
thanks
Originally Posted by scotts300
What offset?
+20 all around
the guy im buying them from had 275/35f and 295/35r but i dont need any wider than a 285 in the rear...
Originally Posted by brandon3434
Will if you do 275 and 285, the "stretch" will be different. The fronts will look more beefy than the rear...Does that make sense? If you're into this look, just go 275, 295...
I agree - 265/285.
Chris
They will look completely different since they're all going on 9.5" wheels. I think 265 is a tad small for a 9.5 and 295 is a tad large for 9.5. Regardless, you should be able to add a little bit of spacer.
Old Jan 6, 2011 | 03:05 PM
  #1463
nismonian's Avatar
nismonian
cool, thanks guys.
Old Jan 6, 2011 | 04:56 PM
  #1464
dkmesa350z's Avatar
dkmesa350z
+20 all around
That's what I was going to recommend...just cause you don't need it...
Old Jan 6, 2011 | 08:07 PM
  #1465
nismonian's Avatar
nismonian
yea i have 285's in the rear on my current wheels and even with the sh!tty v12's i get good traction at the track.. i would rock 305's just for looks but budget is tight right now..
Old Jan 7, 2011 | 05:40 AM
  #1466
BoomerZ33's Avatar
BoomerZ33
Originally Posted by kingpin.andy
New wheels and tires...might get some spacers to fill out the wells a little more perfectly.
SSR Type F Sumitomo HTR Z III
Front: 18x9 +27 275/40
Rear: 18x9.5 +22 265/40
First time modding a car in any way...think I'm doin OK!
looks good dude
Old Jan 7, 2011 | 09:13 AM
  #1467
nismonian's Avatar
nismonian
work vs-xx 19x9 +21 255/35f 19x10 +23 285/35r
Old Jan 9, 2011 | 11:18 AM
  #1468
AmateuRN's Avatar
AmateuRN
My G:
19x10.5 +2 w/ 275's. Camber @ -4.5 rear.
Old Jan 9, 2011 | 02:38 PM
  #1469
SQBassHead's Avatar
SQBassHead
homie g from the last pic.... your offset dont look as aggressive... post up more pics
Old Jan 9, 2011 | 03:01 PM
  #1470
nismonian's Avatar
nismonian
my works are for sale, check the classifieds guys.
Old Jan 9, 2011 | 03:51 PM
  #1471
Waiz's Avatar
Waiz
275 on a 10.5 is not aggressive
Old Jan 9, 2011 | 10:07 PM
  #1472
KingBaby's Avatar
KingBaby
Hardest Setting
correct!
Old Jan 10, 2011 | 03:09 AM
  #1473
Sodero's Avatar
Sodero
My new setup for this coming summer. 19x10 +22 Rpf1's with
305/30. and 255/35 pirelli pzero rosso's.
I can't wait
on this car.
Old Jan 10, 2011 | 10:23 AM
  #1474
scotts300's Avatar
scotts300
I can't wait
on this car.
You plan on rolling, ya? 305 is a little chubby for a 10" wheel, IMO.
Old Jan 10, 2011 | 02:33 PM
  #1475
SQBassHead's Avatar
SQBassHead
Originally Posted by KingBaby
correct!
+1 but it also depends on what tires you have
he has 275 bfg kdw's and we all know they run wide.... so its like someone else running 285 pirrelli, or falkens.. .. maybe 295's on some brands...
true or not??? im pretty sure im right tho
Old Jan 10, 2011 | 02:45 PM
  #1476
Sodero's Avatar
Sodero
Yeah it's already rolled. I agree it's a little chubby but I got a great deal on both the wheels and the tires so I couldn't pass it up. Good thing I like chubby haha.
Old Jan 10, 2011 | 03:27 PM
  #1477
ITOzann's Avatar
ITOzann
Originally Posted by HomieG35
My G:
NICE!
Old Jan 11, 2011 | 06:39 PM
  #1478
350Z_Al's Avatar
350Z_Al
Can anybody confirm that a 19x11 +31mm will clear on the inside edge? It's a fairly high offset I know, I'm not worried about outside and fender clearance, just weather or not the inside edge will have any issues. I don't remember seeing anybody running a wheel that goes that far in.
Old Jan 11, 2011 | 06:41 PM
  #1479
Waiz's Avatar
Waiz
Somewhat true, but only if you tell yourself that
Old Jan 11, 2011 | 09:39 PM
  #1480
Voboy's Avatar
Voboy
I run/ran a 19x10.5 +35 with 285 tire and it cleared just fine... But I never checked if I had more room to work with or not... Offset calculator says it's only a 2MM difference for inner clearance. Most likely will clear... if not you can always run a small 3-5mm spacer.
