Volk High, mid and low pad???
Old Sep 27, 2003 | 10:43 AM
Type R Boy's Avatar
Type R Boy
Default Volk High, mid and low pad???
Which do we use for the GTCs? is that why some ppl are having fitment probs with their Volks?
Old Sep 27, 2003 | 11:02 AM
teh215's Avatar
teh215
pad?
Old Sep 27, 2003 | 12:37 PM
staggered_IS's Avatar
staggered_IS
If you have Brembos, go high pad/disk.
high pad/disk - maximun back spacing to accomodate big brakes
normal - application for most cars w/o aftermarket/big brakes
low - minimum clearance/stock calipers only. usually for the rear, to give maximum lip.
Old Oct 3, 2003 | 06:10 PM
Type R Boy's Avatar
Type R Boy
So is mid and low type acceptable for the rear even with Brembos? I am pretty sure mid type Face2s are ok for the rear.
Old Oct 3, 2003 | 06:20 PM
2003z's Avatar
2003z
Hope this helps:
Pad height and backspacing, or offset are 2 different things, but you probably want at least mid for the rear. If you could get the measurements it would help.
-Offset deals with the mounting point in relation to the wheel width.
-Pad height deals with the mounting point in relation to the back of the 'spokes'
For example (I'm gonna use inches instead of mm, cause its easier) Also, lets call high pad 1.5", mid 1" and low .5" just for illustration purposes.
Take an 8" rim with a +1" offset, it would have 5" from the mounting point (pad) to the inner wheel and 3" to the outer wheel.
If you had a high pad on this wheel, the spokes would be 1.5" closer to the outer edge, i.e. a 1.5" lip.
If you had a low pad, it would only be .5" closer, or a 2.5" lip.
So basically, for two wheels of the same offset and width, pad height will determine lip size. The lower the pad, the bigger the lip.
This is what happens when your pad is too small due to a large lip (I solved the problem with 2mm spacers, it was real close):
Old Oct 3, 2003 | 06:21 PM
2003z's Avatar
2003z
I've got a 4" lip on those wheels, and as you can see, a VERY small pad height.
Old Oct 5, 2003 | 05:00 PM
ihatethatbobbarker's Avatar
ihatethatbobbarker
lets just say i plan on getting something equivalent to stoptechs in size, is +22 enough? anybody know?
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
