Need help on the size of tires i should put on 19inch rims
Hi yall, i need help on the size of the tires i should get on my new Axis supermesh, it is 19x8.5 front and 19x9.5 rear and i was going to use 245/35/19 front n 275/30/19 rear, b/c David at 350zforums recommanded me, but after reading another thread posted by other memeber, he got the exact setup and already has problems on the first day, he has traction control problem and some other issue and i did not want my car to take the risk, so i need some advise from you guys , especially those who have 19 inch w/8.5 n 9.5 setup, i would like to know what is the common size of this setup and what you guys had, please post the size of tires and what kind of problem have you guys encounter after putting aftermarket rims, thanks
Go here: http://www.dakota-truck.net/TIRECALC/tirecalc.html.
Putting 275/30 on the rear means the rear tires are .26" SMALLER in diameter than the front 245/35 tires. That's what is setting off the "slip" indicator. The larger (taller) tires need to be on the rear.
Originally posted by DrDrilZ
245/35 in front
275/35 in rear
corresponds to stock sizes the best for the rim widths youre running
245/35 in front
275/35 in rear
the stock tires are 225/45/18 front and 245/45/18 rear so by going up to 19 you neen to go to 245/35/19 and 275/35/19 to keep the stager and the over all size of the tires the same as stock. yes your rims will be 1" taller but now your tires will be 1" shorter so th overall size stays the same
Originally posted by durobred
are you serious? I thought Dave made a mistake w/ my tires.....i can't beleive they actually meant to put those size tires on my rims
i tried callin like 5 times so far today...i can't get a hold of Dave...either i get the machine, or a busy signal, so i left a message....i hope i can get all this resolved w/out any headaches or too much delay....thigns always seem to go wrong when it comes to me
p.s. if you talk to him anytime soon, please let hime know of my thread in this forum...thanks
David is on a business trip to Japan, so he wont be back until Sunday night, so the only way you can contact him is by email or pm him, but i dont know his email, so i just pm and hope he will check it, anyways, GOOD LOCK TO YOU~
Subarism
East Canada
Sep 23, 2015 06:22 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
