wheel offset help... thanks
Old Jun 20, 2009 | 03:41 PM
zzz350zzz's Avatar
zzz350zzz
Default wheel offset help... thanks
Hi,
I would like to buy this rims with the following spec. Would you please tell me if the offset will fit 2003 350z? Thanks
Product Information
Brand: AXIS
Model: SE7EN MOD
Exterior: Hyper Light
Sizing and Specifications
Rim Diameter: 20 inches
Rim Width: 9 inches
Bolt Pattern (Number of Holes): 5
Bolt Pattern (Pitch Circle Diameter): 114.30 millimeters
Offset: 37 millimeters
Hub Bore: 73.10 millimeters
Old Jun 20, 2009 | 04:06 PM
maXmood's Avatar
maXmood
Under Boost!
yes, it will fit.
Old Jun 20, 2009 | 06:02 PM
omegamanex's Avatar
omegamanex
just an fyi, the stock wheels have an offset of +30, which means these new wheels have a worse offset and will be more sunken in
Old Jun 20, 2009 | 07:56 PM
davidc81's Avatar
davidc81
those offsets are hella weak. your z will look whack. look for something at least +25 or lower.
Old Jun 20, 2009 | 09:31 PM
Bumble Z's Avatar
Bumble Z
if you go that high in offset get some spacers and if your into your Z's speed then fyi 20's will slow you down very bad
Old Jun 21, 2009 | 11:30 AM
mcarther101's Avatar
mcarther101
I agree, those are super weak offsets. Your Z will look better on stock wheels. I've seen hella random-POS Z's with sunken in aftermarket wheels, and it always gives me a /facepalm.
Old Jun 21, 2009 | 12:42 PM
spdtckts's Avatar
spdtckts
agreed with everyone else the old owner of my car got a set of wheels with a crazy weak offset and i hate them...plus they are chrome.
Old Jun 21, 2009 | 01:43 PM
scotts300's Avatar
scotts300
Sort of true. The stock 18x8 +30s will be more "sunken in" than the 20x9 +37s he is asking about. Actually, the 20s would be 5mm further out than the stockers. I agree he should find a lower offset wheel or consider hubcentric spacers. OP - you'll also need a hubcentric ring to step you up to the 73mm bore of the proposed 20" wheel.
Old Jun 21, 2009 | 03:48 PM
Thermal1's Avatar
Thermal1
Ew. please dont.
do more research and figure out what you really want.
Obadabot
Jun 18, 2023 11:31 PM
