Wheel Spacers Noise
Old Jul 27, 2009 | 06:33 PM
Coehsp350Z's Avatar
Coehsp350Z
Default Wheel Spacers Noise
Hey guys, maybe someone can help me out.
Today i installed the Ichiba Wheelspacers V2 on my Z. I was backing out of my driveway and i heard a noise when my car dipped down a little bit. I never heard this noise before the spacers and was wondering if i should be concerned about anything. Anyone else experience anything strange with their Ichiba Wheel Spacers???
Old Jul 27, 2009 | 07:19 PM
Swiffer's Avatar
Swiffer
If you have them mounted properly and tightened down, you shouldnt hear any noises.
What was the noise?
Old Jul 27, 2009 | 08:51 PM
Coehsp350Z's Avatar
Coehsp350Z
What was the noise?
It sounded like a scraping noise, not exactly sure 100% i will have to listen to it more often to see if it comes back. I torqued the bolts down with a torque wrench.
Old Jul 27, 2009 | 08:54 PM
Entaille's Avatar
Entaille
you say they are the v2. were your stock studs sticking out far enough to be anywhere near contact with the back of your wheels? that is my first inclination ...
this is all a guessing game without being able to hear it and see it in person.
Old Jul 27, 2009 | 08:55 PM
JasonZ-YA's Avatar
JasonZ-YA
How wide are your spacers???
from what you described it sounds like at the dip your tire rubbed your fender...........
not anything from spacers....your just think its your spacers making the noise cause thats what you last did to the car, but its due to the spacers....not the spacers themselves...
-J
Old Jul 27, 2009 | 08:56 PM
erichsherrill's Avatar
erichsherrill
it MIGHT be ur tire rubbin the inner fender. i have 25mm spacers and 275 rears and when i hit bumps in the road (especially when i have a passenger) i hear the tire rub. so it might have happened when u hit the dip. the fix to that would be rolling your fenders i havent done it yet im too lazy
Old Jul 27, 2009 | 08:57 PM
JasonZ-YA's Avatar
JasonZ-YA
try backing out of the driveway again......hitting that dip and once you hear the noise stop.....inspect your tires edge and look for contact marks......indications of your tires rubbing your fenders...
what size tires do you have?
what thickness spacers?
-J
Old Jul 27, 2009 | 09:01 PM
Entaille's Avatar
Entaille
the man might be on to something.
Old Jul 28, 2009 | 04:07 AM
Coehsp350Z's Avatar
Coehsp350Z
-J
The tires are stock size, 245/45/18 Rear and 225/45/18 front. The spacers size is 25mm rear and 20mm front. It did sound like a rub, but i just find it hard to believe that it will rub when the car is no lowered..
Thanx for the input so far guys, greatly appreciated..
Old Jul 28, 2009 | 04:15 AM
JasonZ-YA's Avatar
JasonZ-YA
^ check it out/try it and get back to us......let us know..
-J
Old Jul 28, 2009 | 09:20 AM
erichsherrill
my car also isnt lowered but it rubbed
Old Jul 28, 2009 | 09:28 AM
terrasmak's Avatar
You don't have to be lowered to rub , especially when your offsets are all wrong.
Old Jul 28, 2009 | 09:29 AM
scotts300's Avatar
scotts300
He has stock-sized tires on stock wheels - you don't. His rear tires are over an inch more narrow than yours.
Old Jul 28, 2009 | 09:51 AM
erichsherrill
im aware of that i read it too...what do u suggest it is..he hears rubbing....i hear rubbing..he started hearing it after he put spacers on...i started hearing it after i put spacers on....i investigated and it was rubbing inner fenders
Old Jul 28, 2009 | 10:52 AM
Coehsp350Z's Avatar
Coehsp350Z
ok i finally checked everything out. Everytime i hit a bump a lil bit faster than usual it rubs. i pulled out of my driveway and parked the car at an angle and i see the tire rubbing a tad bit, but its nothing bad. All i have to do is fold the inner of the fender a little bit to prevent it from touching and i think i should be good. Im just glad its nothing major.
Old Jul 28, 2009 | 11:22 AM
kensin0429's Avatar
kensin0429
seeeeeeeeeeeee
Old Jul 28, 2009 | 11:30 AM
erichsherrill
good idea bro...
Old Jul 28, 2009 | 11:35 AM
scotts300's Avatar
scotts300
Fair enough. It sounds like you both have spacers that are too large given the rest of your set-ups.
Old Jul 28, 2009 | 11:45 AM
erichsherrill
i have the size spacer i needed to have a flush look...
Old Jul 28, 2009 | 01:08 PM
sry110's Avatar
sry110
To the OP, glad you got it figured out. I agree a slight fender roll should take care of it.
And here's my unsolicited comment of the day: I don't understand why people think it's impossible for their tires to rub just because they do not have lowering springs installed. If your offset & width combination is making the tire stick out enough, and you hit enough of a bump to make the OEM springs compress to the point where the tire wants to tuck up into the wheel well, you're going to rub.
