tire size ?
Old Aug 4, 2009 | 06:36 AM
Bumble Z's Avatar
Bumble Z
Default tire size ?
i seen it asked on other sizes but not sure im getting a set of 18's squared setup but im staggering the tires. my question is will i get a vdc light or have an issue running 245/40/18 in the front and a 275/35/18 in the rear i have a touring model i heard different from several people but not sure which is right
Old Aug 4, 2009 | 07:04 AM
terrasmak's Avatar
Same as every day , you need the 275/40 rear. VDC won't like you , neither will ABS. If you want a square setup get 275/35 front and 275/40 rear.
Old Aug 4, 2009 | 07:21 AM
Bumble Z's Avatar
Bumble Z
yea i figured cuz i seen some base setups get away with it but different profiles i guess work only when the rear is taller then?
Old Aug 4, 2009 | 07:25 AM
terrasmak's Avatar
With a base its not as needed , but for ABS to still function properly you need the proper stagger in tire height from front to rear.
Also the staggered tire height looks better, our rear wheels wells have larger arches that need to be filled.
Old Aug 4, 2009 | 08:11 AM
Bumble Z's Avatar
Bumble Z
My thot was since its a percent of the width it would be close to a 245/40
Old Aug 4, 2009 | 08:26 AM
Front tires are taller than rear.
Old Aug 4, 2009 | 09:46 AM
terrasmak's Avatar
Taller by just a hair, perfect setup if you want staggered on a car that doesn't require a stagger in height. ( RX7 , RX8 , supra)
Old Aug 4, 2009 | 10:36 AM
Bumble Z's Avatar
Bumble Z
thank you you made that alot more clear for me now
Old Aug 4, 2009 | 11:48 AM
scotts300's Avatar
scotts300
Just to clarify, these aren't on the stock 18" wheels, right?
Old Aug 4, 2009 | 09:15 PM
Bumble Z's Avatar
Bumble Z
no they are for rota torques 18x9.5 lol width would be retarded on stockers lol
Old Aug 5, 2009 | 07:47 AM
scotts300's Avatar
scotts300
You'd be surprised how many people do it because it's "cool".
Old Aug 5, 2009 | 03:45 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
Is your local tire shop that you purchased the tires from refusing to swap them out for properly sized 275/40/18's? When you had mentioned the tire sizes they recommended it really shocked me as they didn't even check what year/model your car is and see that you have VDC. I hope everything works out Christian!
-Dan
Old Aug 5, 2009 | 05:10 PM
Bumble Z's Avatar
Bumble Z
i finally contacted them they are going to swap it out for me i talked to them yesterday so im just waiting on the new tires i got the wheels in today fast shipping thanks dan they are beautiful i cant wait to get them mounted ill have pix for you soon
