' WHEELS & TIRES '!!!
Old Oct 9, 2002 | 06:01 AM
  #241
TXSTYLE's Avatar
TXSTYLE
Originally posted by iforged
some 19" Seneka wheels we just did for a E46 M3 for Euro Tuner.
1.5 inch lip in the front
3.0 inch lip in the rear
the 350z with have 2.5 lip in the front
and 2.0 inch lip in the rear
I have not received any "estimates" for your product? For example, the wheels on this bimmer..........?
Old Oct 9, 2002 | 03:59 PM
  #242
Traffic's Avatar
Traffic
Originally posted by Runn
Do anybody know the wheel size and tire size on the HKS black 350z with the Avan Connoisseur.
Looked to me like 19x8.5, and 19x9.5...which would correspond to 245/35/19 and 265/35/19.
Old Oct 9, 2002 | 04:03 PM
  #243
Cazzz Z's Avatar
Cazzz Z
Default If you want to stay conservative
I got them stock 18" chromes for sale, go right on with your tires..
Old Oct 10, 2002 | 07:29 AM
  #244
TXSTYLE's Avatar
TXSTYLE
Exclamation Re: If you want to stay conservative
Check your private message!
Old Oct 11, 2002 | 12:16 PM
  #245
Vlad's Avatar
Vlad
Volk's are nice. Where you guys getting money to spend $2K on wheels?
Old Oct 11, 2002 | 10:23 PM
  #247
iForged's Avatar
iForged
This is exactly how the rims on the 350Z will look
We just did a customers 540i
Polished FS Senekas
www.iforged.com
2.5 inch lip in the front
Old Oct 12, 2002 | 11:23 AM
  #249
sands's Avatar
sands
Here is a post about offsets from ZISME:
http://www.zcar.com/forums/read.php?f=5&i=54625&t=54625
Old Oct 13, 2002 | 07:45 PM
  #250
Cazzz Z's Avatar
Cazzz Z
Default Chromes For Sale
Hey 350SatX, the chrome wheels I got are going for $700.00 for the set..
Old Oct 14, 2002 | 06:03 AM
  #251
hokie350's Avatar
hokie350
Those chrome 18s were a $1,500 for a base/enthusiast option, i remember that much.
Old Oct 14, 2002 | 06:30 AM
  #252
Cazzz Z's Avatar
Cazzz Z
Default $1500.00 Exactly!!
Yep, thats my point, I know that the dealer is at least getting $1500-$1800.00 for a set of Chrome 18s, so when I say $700.00 fo chrome exchange, I shouldn't hear a problem..
Old Oct 20, 2002 | 07:18 PM
  #253
shoalhaven's Avatar
shoalhaven
Question Wheels & Tires
If this subject has been asked before, I apologize in advance.
It has been suggested in another thread that it would be O.K. to put 245's up front and 275's in the rear, using the stock wheels.
I dunno, but 275's seem extreme.
In any event, what do you think the maximum tire sizes should be, using the stock wheels?
I would not want to risk safety and handling.
Old Oct 21, 2002 | 06:46 AM
  #254
Todd@ProDyno's Avatar
Todd@ProDyno
275s out back are not a problem. I actually fit a 285 already. 245 is safe max up front. 255 if you feel adventerous.
Old Oct 21, 2002 | 06:48 AM
  #255
TXSTYLE's Avatar
TXSTYLE
Default Re: Wheels & Tires
That was a terrible suggestion!
You want to stick with a 245 so you won't have "tire-roll" (buldging over your rims) which will inturn cause quick uneven wear. My wheels should be here any day now, and I'm using a 275 on a 9.5' wheel!
Old Oct 21, 2002 | 07:22 AM
  #256
Driven's Avatar
Driven
Seems to be some descrepency on this topic. My only reference is off road tires on various rim widths...with them, there is a HUGE varience of tire widths that can be and are run on the same width rim. Tire wear is a consideration and use is another ie. rock crawling etc...but in some instances the same dimension tire by different manufacturers had up to a 1" varience in recommended rim width!
So could someone educate me on a performance car...tire and rim setup. I already understand changing the setup may change the car's handling. My objective would be to go with the widest tires that can be safely run on stock rims (performance model) that will not notibly degrade performance, or wear terribly.
Old Oct 21, 2002 | 01:55 PM
  #257
PistolPete's Avatar
PistolPete
I wouldn't go with any wider than a 255/45r17 on the stock 17x8" rim. That is a 10" wide tire on an 8" rim, with only 4.5 inches of sidewall to absorb that width change.
My buddy runs 275/40r17 drag radials on 17x8" wheels on his mustang, and it just ain't right. The sidewall have significant buldge, and the tire does not sit flat when properly inflated.
I run 31x10.5r15s on 15x7" wheels on my jeep. This is a 3.5 in difference, but with 8 inches of sidewall to adapt to the change. I couldn't go any wider on that rim without problems.
A 275 tire is almost 11 inches wide. That is too wide for an 8" rim on a 40 or 45 aspect tire. You won't be happy with the results.
I haven't even found anyone running a 255/45 on the stock rear wheel yet. It might rub on the inside.
Old Oct 22, 2002 | 11:25 AM
  #258
mcduck's Avatar
mcduck
Default iforged:
how much are the aero, flux, evo, seneka, and swift rims going to run for the 350Z? in 18" or 19"?
Considering the TE37's, but like a few of those mentioned above. Must know about price soon, though...
Old Oct 22, 2002 | 12:28 PM
  #259
DrDrilZ's Avatar
DrDrilZ
Default Re: Re: Wheels & Tires
what rim did you choose? the kahn's? take pics as soon as you get them.
Old Oct 22, 2002 | 02:39 PM
  #260
TXSTYLE's Avatar
TXSTYLE
Lightbulb
Sure thing. Actually I changed my mind on the Kahn. Not that it's not a fantastic looking wheel, cause' it is! I just decided at the last moment to go with a multi-spoke look wheel. As a matter of fact I received word & tracking # and they should arrive on Thursday! Can you say:
And since I have SOLID confirmation and they will be in my posession in a few days.............I present to you my new wheels!
ANTERA Type 321
19x8.5 Front
19x9.5 Rear
Multi-Piece Wheels
Crafted in ITALY
Rubber: TOYO Proxes T1-S 245/40/19 front <> 275/35/19 rear
