Suggestions needed for Track Wheels on 350Z Nismo
Old Dec 8, 2009 | 11:33 AM
  #101
Sonic1's Avatar
Sonic1
I have problems with 275's in the front with 25mm offset. The rub under extreme driving conditions.
Do not run BFG's. They are some of the worst tires I have ever tried.
Old Dec 8, 2009 | 02:30 PM
  #102
scotts300's Avatar
scotts300
What wheel width and offset? I run a 275 front on 17x9.5" +30 wheels without issue, as well as 17x10" +20 with a 275. The 17x10 +25 with a 275 was >< close to rubbing on the inside, so I decided to run a small shim spacer. Some do, some don't - the Hoosiers run a little wider than other 275 tires.
Old Dec 8, 2009 | 03:22 PM
  #103
Sonic1's Avatar
Sonic1
18 X 10 +25 offset. I thought about running a 5mm spacer to avoid the rub.
Old Dec 9, 2009 | 07:56 AM
  #104
scotts300's Avatar
scotts300
It rubs on the inside arm? That makes sense - try the shim spacer, 3-5mm. That should clear it right up.
Old Dec 9, 2009 | 05:25 PM
  #105
Sonic1's Avatar
Sonic1
Did you have to change the studs out to run a thin spacer?
Old Dec 10, 2009 | 06:29 AM
  #106
scotts300's Avatar
scotts300
No. You get plenty of engagement with the small spacer. I check them often though, especially after every lapping session.
Old Dec 10, 2009 | 06:12 PM
  #107
Sonic1's Avatar
Sonic1
Do you know of a good source for those?
Thanks!
Old Dec 10, 2009 | 10:44 PM
  #108
scotts300's Avatar
scotts300
Thanks!
You can get the shim-type spacers at most any auto store or speedshop. Ebay 'em if you have the time, they should be cheap. I think I have at least one extra set - can check if you're interested and not in a huge rush.
Old Dec 15, 2009 | 10:09 PM
  #109
Stillen Z's Avatar
Stillen Z
I don't think the MB wheels are very light. This site http://www.wheelsbymbmotoring.com/pr...el=Competition has 'em at 28 lb for 17 x 9s. That's pretty heavy. Aren't the 17 x 9 RPF1s about 18 lb?
Old Dec 15, 2009 | 10:16 PM
  #110
Stillen Z's Avatar
Stillen Z
Do you run those with 275s all around and which end needs the spacer to avoid rubbing? I ask because I'm in the market for wheels and tires and am thinking of that size wheel (or 18x9.5) and 275s all around. Thanks for any info.
Oops. Nevermind. I see that you are, indeed, running 275s all around.
Old Dec 15, 2009 | 10:36 PM
  #111
solidsnake's Avatar
solidsnake
Originally Posted by scotts300
Can you fit 275s on the front with that offset? They aren't that light, when compared to SSR Comps or even RPF1s. The cast 17x10s are ~21# (I have them for open tracking, also), and agree they are great value, but 17x10 RPF1s are 17#, and my 17x9.5" SSR Comps (for autox) are 15#, 17x10s SSR Comps are 17#. Sure, there are heavier cast wheels, but these aren't the lightest of 17" wheels for sure.
I like the +22 offset 17x10 FNO1R because you can likely put a 295 on the back, though I doubt I'll be able to match that in the front since my big 275 is already a super tight fit.
275 would fit upfront but would need a 5mm spacer. Right now I have hardly any clearance. I am sure I could fit 295 in back but no one makes street tires in that size,. Biggest I found was 285/40
Old Dec 16, 2009 | 07:46 AM
  #112
scotts300's Avatar
scotts300
Why do you need a spacer with a 17x10 +12? Most can run the 17x10 +25 with a 275 without a spacer. I need the small shim because the 275 Hoosiers are so wide.
Old Jan 13, 2012 | 12:37 PM
  #113
Creepin!'s Avatar
Creepin!
How does a set up like 17x9.5 +18 front, and 18x9.5 +15 rear (enkei rpf1) sound? Also for tire size, would it be possible to run 255 all around or is it better to go for a wider size? Thanks!
Old Jan 14, 2012 | 10:05 AM
  #114
Sonic1's Avatar
Sonic1
I'm now running RPF1's 18x9.5 front with 275 and 18X10.5 rear with 295 Hoosiers. I did have my fenders rolled to clear with a wider stance in the back. Worth it for the extra grip!
RiujinZero
Apr 16, 2021 11:31 AM
codek
Sep 27, 2015 03:21 PM
pdexta
Sep 14, 2015 11:27 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
