first set of rims
Old Aug 16, 2009 | 10:49 AM
ag0240's Avatar
ag0240
Default first set of rims
hey guys im guna be picking up my first set of rims for my z. the size of the rims are 19x9.5 +28et (front) and 19x10.5 +11et (rear). my question is will these rims fit on the z without having to roll the fenders? and also i dont really know too much about wheel spacers but would these need them?
Old Aug 16, 2009 | 10:59 AM
johzp's Avatar
johzp
depends on drop, tire size, camber.
the 10.5+11 might rub in the rear, the fronts should be fine though
Old Aug 16, 2009 | 11:28 AM
ag0240's Avatar
ag0240
i havnt dropped the car at all
Old Aug 16, 2009 | 11:34 AM
pnkZ33's Avatar
pnkZ33
Default rims
well the thing about wide rims like that is when you make hard corner turns or just making a 20 mph turn into a street your traction control system will come on...because the cars thinks its losing grip............the rims are too wide...anyways thats my issue when i got some 19 with same spec like urs...
Old Aug 16, 2009 | 11:55 AM
ag0240's Avatar
ag0240
really then that would cause a problem
Old Aug 16, 2009 | 12:04 PM
Jacob350z's Avatar
Jacob350z
best option is to roll the rears. its not a hard process and in the end is def worth doing just incase of rub. with those offsets and that size rim you might want consider doing it. you might be a little far out so you may need a roll
Old Aug 16, 2009 | 01:15 PM
That will work. Just stretch the rear tires.
Old Aug 16, 2009 | 02:09 PM
ag0240's Avatar
ag0240
stretch the rear tires? rolling fenders?
Old Aug 16, 2009 | 05:49 PM
terrasmak's Avatar
I'll bet having the wrong tire size on wide/any wheels will more likely cause that to happen.
Old Aug 17, 2009 | 05:24 AM
Thermal1's Avatar
Thermal1
Dont give advice when you dont know what you are talking about.
His TCS is angry because he has the wrong size tires on. It has nothing to do with width.
OP, I would run a spacer on the front like 15mm or so. That will make the front offset +13 which is obviously much closer to matching the +11 rears.
You have a fairly aggressive setup. You will want to roll the rears. Once you do, you could probably run a tire size like 245/35/19 front and 275/35/19 rear.
Old Aug 17, 2009 | 11:27 AM
scotts300's Avatar
scotts300
As others have said, this is due to the tires sizes on your wheels, not the size of the wheels themselves.
OP - the rears will be a tough fit, do you know what size tires are on them already or have you begun to think about tire sizes? As David said, you may need to run the "stretched tire" look, which means you put a smaller tire than is typically recommended given the wheel width.
A 10.5" wheel should have a 285-sized tire on it at a minimum. 275 will have a little stretch, 295 would be ideal, 305 would be ok also.
Old Aug 17, 2009 | 12:12 PM
ZS14RR's Avatar
ZS14RR
roll the rears and dont stretch youre tires.
the rear offset are ok.
Old Aug 17, 2009 | 12:33 PM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
I say roll your rears and run some beef on the rear but thats just my opinion. On offsets its better to go low than high on a Z
Old Aug 18, 2009 | 05:54 AM
ag0240's Avatar
ag0240
would i have to roll my fenders with a tire 19X10.5 +23?
Old Aug 18, 2009 | 06:19 AM
Bumble Z's Avatar
Bumble Z
nah not on +23..stay with 11 if you gotta roll em roll em no big deal..the aggressive offset is sick
Old Aug 18, 2009 | 06:32 AM
Entaille's Avatar
Entaille
I was wondering when someone would chime in about the awkward offset variance. definitely get a spacer for the front.
Old Aug 18, 2009 | 06:09 PM
scotts300's Avatar
scotts300
Depends on what size tire. Our 305/30/19 on 19x10.5 +28 is very close (no roll). There is room on the inside, it's tight on the outside.
Old Aug 18, 2009 | 06:23 PM
MethodRN's Avatar
MethodRN
For Sale
BWAHAHAHAHAHAHA
As for wheel size, front could stand to have a spacer. Rear size is aggressive and would work, but would require to modify rear fender if you decide to drop the car. You would also have to run some negative camber depending on tire size.
Give us tire brand and sizes and we'd be able to give you a better answer.
Old Aug 18, 2009 | 06:25 PM
MethodRN's Avatar
MethodRN
For Sale
I run 11" rear wheels and have no issues with TCS coming on. It's about tire size and rolling diameter and not width.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
