these sizes fine for 03z?
Old Aug 18, 2009 | 01:26 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default these sizes fine for 03z?
Just wanted to make sure these sizes would fit fine of my Z.
FRONT - 19x8.5 5x114.3 20 offset on 245/35ZR19 93Y
BACK - 19x9.5 5x114.3 20 offset on 275/35ZR19 96Y
Thanks for any input.
Old Aug 18, 2009 | 02:43 PM
GIANNI's Avatar
GIANNI
thay will be just fine.i have 20' on my z with 245/25/20 ft. 295/25/20 bk. i have no problem with them at all.
Old Aug 18, 2009 | 02:52 PM
ZS14RR's Avatar
ZS14RR
what are you trying to achieve with this set-up??
just that it will fit??
it wont be near to looking flush .
Old Aug 18, 2009 | 03:34 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
I found the place I'm getting the tires from have 35 for fronts so ill go with that. I don't track and hate the look of the stock rims so I just want something that will look better. I read that lower offset is better for the Z and that an offset around 20 is perfect. Anything else I should be aware of?
Old Aug 18, 2009 | 03:52 PM
ZS14RR's Avatar
ZS14RR
well I am not a master of offsets but the front set-up seems it gonna be very near to stock set-up. the rear are gonna fill it a tad bit but people usually go like 10 +20 or even bigger.
it all depends on what you are trying to achieve..
Old Aug 18, 2009 | 04:56 PM
terrasmak's Avatar
will fit fine, look OK , and will not rub.
May be fine for you in the long run , and get replaced.
Old Aug 18, 2009 | 05:31 PM
zerafian's Avatar
zerafian
yes
Old Aug 19, 2009 | 11:49 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
+1 perfectly fine for fit and overall diameter.
Old Aug 19, 2009 | 11:53 AM
Jacob350z's Avatar
Jacob350z
will be sunk in but could always add spacers.
search button is your friend.
Old Aug 19, 2009 | 06:53 PM
Spike100's Avatar
Spike100
Tire sizes are perfect. Offset will look very good.
--Spike
Old Aug 20, 2009 | 01:10 AM
SoCal-Zzzz's Avatar
SoCal-Zzzz
When I called to get a quote the guy recommended 38 offset on the fronts I think it was and 20 on the back? Do some cars look better with higher offsets? Is 20 offset all around going to look the best in your guys opinion?
Old Aug 20, 2009 | 09:34 AM
Thermal1's Avatar
Thermal1
20 or lower. 38 is terrible
Old Aug 20, 2009 | 04:07 PM
Spike100's Avatar
Spike100
--Spike
pr_350z
Oct 1, 2015 05:03 PM
