quick noob question about mounting new wheels
Old Aug 27, 2009 | 10:22 AM
dakota9812's Avatar
dakota9812
Question quick noob question about mounting new wheels
i recently just got the 370z sport rims with the stock bridgestone re050 tires. i want to mount them on asap but im a noob when it comes to most stuff. when replacing all 4 wheels do i need to do anything extra like balancing, aligning, etc? or can i just jack the car up, unbolt the old wheels, and put these on? thanks
Old Aug 27, 2009 | 10:29 AM
terrasmak's Avatar
i take it your putting the 370 wheels on your 350, well first you need to buy new front tires, you will probably also want some spacers.
Old Aug 27, 2009 | 10:34 AM
dakota9812's Avatar
dakota9812
why do i need front tires? i read numerous threads about people putting these wheels on their 350z and nobody mentioned anything about putting new front tires. im also aware about the spacer issue, but for right now im just wondering about how i go about putting them on.
Old Aug 27, 2009 | 11:25 AM
I assume that the tires are on the wheels and balanced. Bolt them on. If they are NOT balanced you will figure it out fast.
37OZ wheels may have an unusual offset. Careful when installing. The wheel may not clear the brake caliper.
Old Aug 27, 2009 | 11:39 AM
dakota9812's Avatar
dakota9812
ya im definitely gunna be running spacers soon i just dont have them yet and wanna get the wheels on. but ive seen other users who have got them on fine
Old Aug 27, 2009 | 12:05 PM
lgear080's Avatar
lgear080
I think it's appropriate to make sure they're balanced and you're aligned
properly. Otherwise a few thousand miles down the road your inner tread
could be destroyed. post photos.
Old Aug 27, 2009 | 12:15 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by lgear080
post photos.
Old Aug 27, 2009 | 01:35 PM
DavesZ#3's Avatar
DavesZ#3
Here you go... learn from others who have already experienced this first-hand...
https://my350z.com/forum/wheels-and-...n-a-350-a.html
https://my350z.com/forum/wheels-and-...s-on-350z.html
Old Aug 27, 2009 | 04:14 PM
dakota9812's Avatar
dakota9812
thanks but i already went through all those threads. the fact that i have the 370z rims really isnt the important part, it was just how i go about getting them on my car.
Old Aug 27, 2009 | 05:26 PM
Done Deal DR's Avatar
Done Deal DR
Step 1: Take old wheels off
Step 2: Put new wheels on
If you can't safely jack a car up, remove lug nuts, swap wheels, and torque the lugs back down you should probably just take them to a tire shop. I have no faith that you wouldn't kill yourself. On second thought...J/K
But seriously, whats the hold up? Have you never done this?
Old Aug 27, 2009 | 05:29 PM
DavesZ#3's Avatar
DavesZ#3
The one thing I haven't seen mentioned here is Tire Pressure Sensors. What's your plans there? New wheels have sensors in them? Plan on moving them from old wheels to new wheels or getting system reprogrammed for new sensors?
Old Aug 27, 2009 | 08:39 PM
dakota9812's Avatar
dakota9812
i have done this before with 1 or 2 wheels, but i just never put 4 new rims and tires on so i wasnt sure if there was anything else i needed to do.
Old Aug 28, 2009 | 08:56 AM
dakota9812's Avatar
dakota9812
today i got the wheels on but the fronts rub against the control arm at all times. will a spacer fix this? if so, id like to not have to replace my lugs so what size should i get so that the wheels wont rub against the control arm but i can keep my stock lugs?
Old Aug 28, 2009 | 09:32 AM
DavesZ#3's Avatar
DavesZ#3
If you'll look in the threads I referenced before, two points to note are:
1) spacers up front are required.
2) you have to use the 370 lug nut with the 370 wheels, apparently, they are different than the 350z lug nuts and don't torque down properly.
Old Aug 28, 2009 | 10:07 AM
Done Deal DR
If you can do 1 or 2 wheels you can do all 4. For simplicity jack one side up at a time and put them on. It's no different that putting on 1 or 2, if the tires were already balanced you should be good, but if the overall height of your setup is much different than stock you may need an alignment.
http://www.1010tires.com/tiresizecalculator.asp
As Dave pointed out, if you have a TPMS on your Z you will also need to have the sensors installed in the new wheels. You'd want a wheel and tire shop to perform this.
Old Aug 28, 2009 | 10:09 AM
Done Deal DR
Good info Dave.
Old Aug 28, 2009 | 10:38 AM
dakota9812's Avatar
dakota9812
ok so im gunna go with 20mm spacers. should i be all set now with the control arm rubbing issue? and also could you give me an example of some aftermarket lug nuts that will work.
p.s. sorry for all the questions im just new to all this
Old Aug 28, 2009 | 11:39 AM
Done Deal DR
I can't speak to the lug nuts, but a 20mm spacer should resolve your control arm rubbing issue.
Old Aug 28, 2009 | 11:49 AM
DavesZ#3's Avatar
DavesZ#3
Sorry, but I don't know what the difference in lugs nut is yet.
Old Aug 28, 2009 | 01:26 PM
NismoZ_840's Avatar
NismoZ_840
Okay is the OP really a computer, alien, or a 3yo?
http://lmgtfy.com/?q=370z+lug+nut
Confucius say "Beware the quick question for it is never quick"
