help me
Old Sep 5, 2009 | 10:26 PM
rd808's Avatar
rd808
Default help me
this is gonna sound so noobish but what are the offsets supposed to be for a Z...im gonna buy some gt-vs 19x9.5 19x10.5...it said the fronts were +30 and rears were +24...would that work on a 06' enthusiast??? plz lemme know!!!!!!!
Old Sep 6, 2009 | 12:16 AM
danieluser's Avatar
danieluser
supposed to be.. you mean as in stock?
18x8 +30 front or rear
18x8 +30 / 18x8.5 +33
unless you have track or nismos or even the 17"s lol
anyways google search "350z wiki wheels"
Old Sep 6, 2009 | 04:59 AM
terrasmak's Avatar
Not aggressive, but perfectly fine. The proper offset for your car is 30, but most of us like to run down in the teens for 9.5 10.5 combo's.
Old Sep 6, 2009 | 06:21 AM
Offset for wheels is not "supposed to be" anything. The possible combinations of wheel width and offset is infinite.
Old Sep 6, 2009 | 12:52 PM
rd808's Avatar
rd808
ok when pplz say its agressive???whats that mean???thanks guys..!!!
Old Sep 6, 2009 | 01:05 PM
zerafian's Avatar
zerafian
look through the aggressive offset and stretch tire threads. if you look at the pics and read the specs they state you will learn quickly what it means.
As for your rims....yes that will fit just fine.
Old Sep 6, 2009 | 01:07 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Sep 7, 2009 | 12:31 AM
rd808's Avatar
rd808
yeah thanks guys...i just test fitted em today any they sat flush with a spacer up front...thanks for the info!
Old Sep 7, 2009 | 07:41 AM
terrasmak's Avatar
Well to keep your pivot angles and other aspects of your suspension functioning as designed the offset will be 30.
Old Sep 14, 2009 | 02:21 AM
rd808's Avatar
rd808
okay thanks...another ? why sometimes i drive up a hill my trans keeps slippin???i only got 24xxx and "well taken care of"...says the previous owner...and when in gear i hit the gas and it kinda like boggs for a while..sometimes even 6-10 secs...then goes back to gear...idk if that makes sense but if anyone knows what might be happening plz lemme know?!?!?
Old Sep 14, 2009 | 09:58 AM
scotts300's Avatar
scotts300
Although your posts give me a headache, I will try and help anyway. It sounds like you have a clutch problem. Sellers will tell you whatever you want to hear to sell a car, including the dealership.
Old Sep 14, 2009 | 11:52 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Old Sep 14, 2009 | 01:42 PM
TheFarmer's Avatar
TheFarmer
Do you have an automatic? I don't understand the part where it was in gear and then 6-10 seconds later it goes back into gear.
Old Sep 14, 2009 | 02:01 PM
terrasmak's Avatar
Do you get a slip light? If so , what are your tire sizes.
Old Sep 14, 2009 | 05:18 PM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
Sounds like traction control is intervening. Make sure your back tire is 0.8~1" taller then your fronts. Having a front tire same or taller then the rear is going to cause that "bogging" which is the conputer thinking your car is losing traction.
Old Sep 14, 2009 | 08:36 PM
rd808's Avatar
rd808
what i mean is when im driving in gear...the slip indicator comes on...and for a couple seconds it boggs...then eventually im guessin it will go bak into gear cuz it runs fine again...???but the slip light comes on...ok...my front tires are 225/40 19 and rears are 275/30 19...sorry for the HEADACHE
Old Sep 14, 2009 | 08:59 PM
scotts300's Avatar
scotts300
Front tires are taller than the rears - VDC doesn't like that. 225/275 is an odd combination regardless.
Old Sep 14, 2009 | 09:58 PM
O_SO_ICY_Z's Avatar
O_SO_ICY_Z
yeah your front tires being taller than your rears is causing your car to think its slipping...make sure you buy correct tire sizes on your new wheels
Old Sep 15, 2009 | 12:47 AM
rd808's Avatar
rd808
Default thanks
k so what tire size should i go with??
Old Sep 15, 2009 | 06:10 AM
terrasmak's Avatar
255/35 front and 285/35 rear , 275/30 front 285/35 rear, 275/30 f 295/30R , 245/35f 275/35r, 255/35f 275/35r , and the list could keep going on for a while.
