buying new tires need help
Old Sep 9, 2009 | 11:41 AM
350ZnFuture's Avatar
350ZnFuture
Default buying new tires need help
Hey guys right now Im running 275/40/18 in the rear whats the lowest width I can run im lowered on eibach sportlines thanks guys, also is the lower the width the cheaper the tire?
Old Sep 9, 2009 | 11:43 AM
TheFarmer's Avatar
TheFarmer
What are the specs of your rear wheels?
Old Sep 9, 2009 | 11:49 AM
350ZnFuture
18 inch +20 offset not sure on how big
Old Sep 9, 2009 | 01:15 PM
Yes. Same brand a 255 mm tire will be less expensive than a 275 mm tire.
Old Sep 9, 2009 | 04:00 PM
350ZnFuture
so should I got with a 245 on the rear or a 255 or does it really matter which? also i have 17s on the front running 205/40/17
Old Sep 9, 2009 | 04:05 PM
terrasmak's Avatar
Stock size 245/45-18 and call it good.
Old Sep 9, 2009 | 04:07 PM
350ZnFuture
im lowered on eibach sportlines... you dont think the 45's will rub?
Old Sep 9, 2009 | 04:48 PM
TheFarmer's Avatar
TheFarmer
No it shouldn't rub. 245/45-18 is same diameter as 275/40-18 (The tire size you have now as you stated). It's just a skinnier tire than the 275.
Old Sep 12, 2009 | 01:03 PM
350ZnFuture
so 245 series tires will be fine or does it matter the length of the rim?
Old Sep 12, 2009 | 05:15 PM
350ZnFuture
btw im running 205/40/17 on the front so would 245/40/18 be ok?
Old Sep 13, 2009 | 08:12 AM
Yes the width of the wheel, which you are not telling me, matters.
Old Sep 13, 2009 | 09:09 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Old Sep 14, 2009 | 10:08 AM
scotts300's Avatar
scotts300
205/17 front and 275/18 rear? Are you sure about that? If the 205 is right, it's not likely you can safely put on a 245. Without knowing the width of your rear wheel, anyone suggesting another tire size is merely guessing. You could have an oversized 275 on a 8" wheel for all we know.
Old Sep 15, 2009 | 11:37 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
Need to know wheel width to accurately answer the question.
Old Sep 15, 2009 | 04:06 PM
350ZnFuture
went with the 275 for the new tires the wheel was wide maybe 10 inch , the fronts are 255/40/17 sorry
Old Sep 15, 2009 | 04:17 PM
dhays's Avatar
dhays
Wow....
Old Sep 15, 2009 | 09:26 PM
scotts300's Avatar
scotts300
You went from a 205 to a 255 on a 17" front and a 275 on an 18" rear? Odd.
Old Sep 16, 2009 | 03:27 AM
350ZnFuture
i was wrong about the fronts when I first told you guys, they were 255's 40 on the front the whole time
Old Sep 16, 2009 | 07:54 AM
terrasmak's Avatar
On 17's or 18's up front?
Old Sep 16, 2009 | 09:32 AM
jerseymike68's Avatar
jerseymike68
thanks for these information
