Rubbing front 255/35/19 on +22 9.5 LE37s
Old Sep 19, 2009 | 01:03 AM
itsjiggajames's Avatar
itsjiggajames
Default Rubbing front 255/35/19 on +22 9.5 LE37s
Everytime I enter a slanted driveway I rub with a 255/35/19 +22 9.5inch LE37... the fronts are already rolled, so nothing I can do about this.. what do you guys do with this setup? I know some people are running 255/35/19 on a +12 TE37 so any input would help. thanks
Old Sep 19, 2009 | 01:09 AM
quakerroatmeal's Avatar
quakerroatmeal
There's 1 screw that's right in the middle of your fender liner, that's where mines kept rubbing at I took it off and now I no longer rub. There are other screws holding the fender lining up as well so it wasn't that big of a deal to take that 1 screw out.
Old Sep 19, 2009 | 02:28 AM
itsjiggajames
thanks, ill try this tomorrow!
Old Sep 19, 2009 | 05:32 AM
DavesZ#3's Avatar
DavesZ#3
Is your car lowered? I have the same setup on the front (LE37 255/35 +22) and have never had an issue with the fronts, only the rears before rolling them.
Old Sep 19, 2009 | 08:03 AM
zerafian's Avatar
zerafian
^^+1
It wont cause any harm if you remove it...but Im surprised your getting rubbing at all...like dave asked, are you dropped?
Old Sep 19, 2009 | 08:13 AM
Chebosto's Avatar
Chebosto
and how much camber r you running?
Old Sep 19, 2009 | 10:37 AM
itsjiggajames
-1.9 fronts and yes i'm lowered.. when the tire is turned in either direction I only have millimeters of clearance; when I go up an incline the tire touches the fender
Old Sep 19, 2009 | 11:06 AM
zerafian's Avatar
zerafian
no wonder, your dropped over an 1" and your camber isnt that low. Just adjust to like-2.5 and take that bolt out from under the fender wall.
Old Sep 19, 2009 | 12:27 PM
Voboy's Avatar
Voboy
Dang +22 rubs w/ 255? I didn't know you needed that much camber to run +12...
For you guys that removed that screw, is your fender making any noises when driving on the freeway or anything?
Old Sep 19, 2009 | 01:17 PM
quakerroatmeal
No noises, the fender lining is still on there quite tight cause there are 1 screw in front of it and in the back of it.
Did it solve the problem james?
Old Sep 19, 2009 | 01:45 PM
Crom's Avatar
Crom
+1....
Old Sep 19, 2009 | 06:28 PM
itsjiggajames
I haven't went up any steep driveways yet.. i'll report back soon
Obadabot
Jun 18, 2023 11:31 PM
