rear tire cupping
on
rear tire cupping
hi,
I checked my tires today, and both rear tires are cupping pretty bad...and slight cupping in the front...my car is 2006 lower on HKS hypermax coilover...is there anything to do with camber, coilovers? or just need to get my both front and rear toe fixed
on
this is not my tire, i took it from the internet.. but my rear tires looks this, is this tire cupping or tire feathering?? its really make alot of noise especially in lower speed. how to fix it?? im getting tires soon
on
yes, im getting a new set of tires soon...so basically new tires and alignment would prevent this? tires are so expensive...and btw..can the Z adjust front toe w/o any toe bolts?
That causes the tires to "scrub" against the pavement. This can cause much worse wear than camber, which is when you're behind the car and your wheels also look like / \ .
When you drop the rear (basically anything more than half an inch) you'll need to get a rear camber kit and new toe adjustment bolts. Get both of those items installed and then have the rear aligned.
This is camber wear- notice how toe has an alternating light/dark pattern whereas camber is one solid stripe.
The rear has both camber and toe adjustment, but both will get maxed out with anything more than a conservative, drop, which is why you need to get the new parts. Those aftermarket parts give you more adjustment to play with, which is necessary if you want to get back into alignment (and stop burning rubber off).
You can get the front toe feathering fixed without a kit. This is a very common issue with the 350z.
08-06-2021 06:19 AM
