Need help choosing offset +18 vs +38
Old Oct 15, 2009 | 01:05 PM
halfrice's Avatar
halfrice
Default Need help choosing offset +18 vs +38
Going to order some enkei rpf1 17x10 all around. They make them in 2 offsets, +18 and +38. Im aiming more towards the +18 thinking id probably have to run spacers with the +38. Anyone have experience with these wheels and offsets? Im hoping the +18 wont be too aggressive. Currently on 06+ non brembo's but planning on upgrading to brembo's in the near future if that matters for the wheel clearance. Planning on running 275/40/17 tires and cars on JIC flt-a2 coilovers. Thanks in advance.
Old Oct 15, 2009 | 01:32 PM
terrasmak's Avatar
How much camber do you plan to use? YOu will need a lot to clear the front tires.
Old Oct 15, 2009 | 02:32 PM
halfrice's Avatar
halfrice
i have cusco front camber a arms, but wouldnt want too much camber as i will be using this for track, im guessing i should just roll my front fenders with the +18
Old Oct 15, 2009 | 03:03 PM
raf84ny's Avatar
raf84ny
You may want to check with owners of Volk GT-S , those have aggresive offsets +17; +18 . I belive people have to cut/roll fenders if they are lowered. GL
Old Oct 15, 2009 | 03:18 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Get et.18 on the back
and et.38 on front (will need spacers but et.18 in front will be brutal)
Old Oct 15, 2009 | 08:26 PM
TheFarmer's Avatar
TheFarmer
+18 for rear. I'm running 19x10.5 +18 rears with 285 wide tires.
Old Oct 16, 2009 | 08:29 AM
Done Deal DR's Avatar
Done Deal DR
Bingo.
A 10" wide in the front with +18 is doable, but would need absolutely wicked camber if you wanted to run a 275.
You'd probably be better off getting the +38 front with maybe a 10mm spacer. That should fit for sure, but if it was me, I'd keep looking until I could find a wheel with the proper offsets. Alas, your wheels and your money = your choice.
Old Oct 16, 2009 | 09:27 AM
halfrice's Avatar
halfrice
hmmm considering 17x9 all around now as they have them in +22 offset. Would you think there would be a noticable difference in traction if I decided to stay with the 275/40/17 size tires?
Old Oct 16, 2009 | 10:05 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Why te hell dont you run 17X9 et.22 front and 17X10 et.18 rear??
Thats perfect!
People seem to forget the Z was made to have staggered wheels..........
TrboMike
North East
Sep 28, 2015 06:36 PM
Tochigi_236
Sep 27, 2015 03:40 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
