Question about aspect ratio.
Old Oct 28, 2009 | 04:36 PM
MarvinMartian's Avatar
MarvinMartian
Question Question about aspect ratio.
I am pricing new tires. And I know jack-**** about tire sizing.
I've discovered that if I look at a 225/40/18 tire for the front, as opposed to the OEM size, it is up to 35% cheaper.
What danger might there be if I were to opt for a 225/40/18 front tire and an OEM 245/45/18 rear tire?
Old Oct 28, 2009 | 07:50 PM
dhays's Avatar
dhays
You don't say what year and trim your Z is. I'm assuming that your stock tires are the 224/45 front and 245/45 rear?
If that is the case, I think you will be really unhappy with the result of a 224/40 front. The 225/40 is almost an inch shorter than the stock front tire. This would result in a stagger of about 1.6 inches which will likely create issues with your VDC or traction control. I'd stick with the stock size tire if I were you.
What tires are you looking at where there is such a large difference in the pricing?
Old Oct 28, 2009 | 09:33 PM
17 months is plenty of time to study here: https://my350z.com/forum/wheels-and-...read-here.html
Old Oct 28, 2009 | 11:18 PM
terrasmak's Avatar
Look for 245/40 fronts , they will maintain the proper stagger and its a more popular size than stock.
Old Oct 29, 2009 | 07:26 AM
MarvinMartian
2008 Enthusiast, stock wheels.
225/45/18 front.
245/45/18 rear.
Toyo Proxes 4
Old Dec 1, 2009 | 06:04 AM
o2sys's Avatar
o2sys
I have a similar situation as the OP,
I plan on putting 225/40/18 fronts and 225/45/18 rear for my winter tires.
But as Terra said 225/40 is .9" smaller than OEM size but if i put 225/45 for the rears, i would still be keeping similar staggered ratio compared to stock right???
My NEW diameter would be 25.1"/F 26"/R
OEM diameteer is at 26"/F 26.7"/R .2" difference overall
Old Dec 1, 2009 | 01:07 PM
Spike100's Avatar
Spike100
Question: Do you have one set of wheels, and you plan to swap your summer and winter tires on the same wheels?
--Spike
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
