rear tire wear???
Old Dec 2, 2009 | 12:59 PM
TJGILROY's Avatar
TJGILROY
Default rear tire wear???
...i never!!!! spin out but i had my tires off yesterday and was comparing how the front tread has kept so well while the rear looks half as good....anybody had any experience with this if you are one not to burn out a lot???
oh yeah...all the tires got put on the same time around a year ago...
Old Dec 2, 2009 | 01:13 PM
velocityracer's Avatar
velocityracer
check your camber/toe settings, but the rears usually go out first before the fronts on a RWD car
Old Dec 2, 2009 | 01:27 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Even if you're not doing burnouts, the tire wear on a RWD sportscar like the Z will be high. I usually wear out two sets of rears for every set of fronts.
Old Dec 2, 2009 | 02:16 PM
I always give you a break because I think your questions are legitimate:
Generally rear wheel drive vehicles will wear rear tires fastest than front.
Generally front wheel drive vehicles will wear front tires fastest than rear.
90 percent of vehicles on the road have the same size tires all around. You can do a X-rotate to even out wear. This is not possible with the 350Z.
Old Dec 3, 2009 | 07:43 AM
TJGILROY's Avatar
TJGILROY
Generally front wheel drive vehicles will wear front tires fastest than front.
appreciate the sympathy david, call me stupid but it seems that if the fronts are smaller they make more rotation to keep up with the rears rotation, seems like it would be the other way around...thanx for the feedback guys!...it was just a question and you guys answered...always ask the guys with the cars..thanks again
oh yeah, would it also help to get the tires balanced every now and then since we can't rotate our tires or would that be a waste???
Old Dec 3, 2009 | 07:44 AM
TJGILROY's Avatar
TJGILROY
easy way to do that??? or a shop? i like doing what i can...easy?
Old Dec 3, 2009 | 08:28 AM
No.
Old Dec 3, 2009 | 08:42 AM
cheshirecat79's Avatar
cheshirecat79
Any tire that's putting the power from the engine to the ground is going to wear out more due to the torque transferred from the tires to the ground. Even if you aren't "burning out", there is still friction between the tires and the ground when you accelerate.
A 2 to 1 ratio of replacing rears to fronts on the 350z is pretty normal, as another member mentioned.
There's nothing you can do about it other than try to keep your alignment set correctly. Getting it done once a year should be adequate.
Old Dec 3, 2009 | 09:05 AM
TJGILROY's Avatar
TJGILROY
good to know, thanks guys!
Old Dec 3, 2009 | 04:31 PM
terrasmak's Avatar
The only thing you can do is have th tire flipped , make the outside the new inside tire. you can't do this with all tires.
Old Dec 3, 2009 | 08:48 PM
gregom's Avatar
gregom
Yeah a lot of performance tires have directional tread... in which case we cant swap side for side.
I don't know what you guys consider normal but I go through 4 sets of rears a year and 2 sets of fronts a year. I do a few track days a year and several auto-x's a year, along with daily driving and plenty of spirited driving. But I have wider than stock sizes with stock power so I don't wear nearly as fast, but still fast enough.
Old Dec 4, 2009 | 04:49 AM
TJGILROY's Avatar
TJGILROY
dang...that's a lot!
Old Dec 4, 2009 | 04:28 PM
Spike100's Avatar
Spike100
Here is a situation where you might see more equal wear of your front and rear tires on a rear-wheel drive car:
If you spend a lot of your driving time on expressways during rush hour and you are constantly doing “stop-and-go,” you will wear your front tires more than the rears each time you apply the brakes to slow or stop your car. Whenever the front of your car dips when braking/slowing, there is more wear on your front tires than your rear tires.
Just presenting the “counterpoint,”
--Spike
Old Dec 8, 2009 | 07:23 PM
Twister350Z's Avatar
Twister350Z
+1!
Old Dec 9, 2009 | 07:50 AM
TJGILROY's Avatar
TJGILROY
Will do
Old Dec 9, 2009 | 11:23 AM
mistanismo's Avatar
mistanismo
Brand of tire and specs?
Old Dec 9, 2009 | 05:24 PM
Spike100's Avatar
Spike100
--Spike
Old Dec 10, 2009 | 06:38 AM
scotts300's Avatar
scotts300
Sounds like you need a dedicated set of autox/track tires. No one tire is good for all 4 applications.
