Can I run these without a problem?
Old Dec 30, 2009 | 01:21 PM
xxRayzor's Avatar
xxRayzor
Default Can I run these without a problem?
So right now, im running the stock 225/45/18 and 245/45/18 setup on my '03 touring. Im planning on changing to 18x9.5 +15 all around and maybe dropping it on eibach sportlines for now pending how much of a fender gap there is. Should I be able to run it without any major issues?
Old Dec 30, 2009 | 02:13 PM
singh's Avatar
singh
_______________
sounds like the rpf1 specs..
are you asking if you can use the same tires? Well to answer that I would NOT use 225's on a 9.5in wheel. The 245 is okay i guess..
what i would use for 9.5in wheel:
front - 255/xx/18
rear - 275/xx/18
xx = 35 or 40 depending on how thick you want your sidewall..
i don't think you would rub if you went with above tires in a 35 profile..
Old Dec 30, 2009 | 02:33 PM
theianmcdougall's Avatar
theianmcdougall
those tires will fit fine, the front will be a little stretched but who cares if you dont have to buy new tires and i dont see why you would have any issues
im running a 225/40 in the front on a 9.5
i suggest def dropping it though, rims + stock ride height - yucky IMO
Old Dec 30, 2009 | 03:23 PM
xxRayzor's Avatar
xxRayzor
my friends s14 is running 225 on his 9.5's and 245 on his 10.5's and they dont seem too stretched, so for now, im not worried about a new set of tires, its just whether or not itll clear everything; which after what you said, sounds like it will. ill def be getting a matching wider set of tires once its time though. and yeah i plan on dropping it on sportlines asap lol
Old Dec 30, 2009 | 03:25 PM
terrasmak's Avatar
you will clear by miles. A 275/40 rear on those wheels fits and 255/40 front on those wheels and offset fits fine. Those i mention are the same (proper ) tire height and just wider.
Old Dec 30, 2009 | 03:37 PM
Go with your plan as is. After the wheels and tires are on the car you can decide if wider tires are needed.
Old Dec 30, 2009 | 04:17 PM
xxRayzor's Avatar
xxRayzor
thanks for the input haha. now i feel more confident on this purchase.
Old Jan 4, 2010 | 01:51 AM
Twister350Z's Avatar
Twister350Z
Let us know how it works out.
Twister350Z
Uriyo_
Sep 8, 2021 08:46 AM
