Guess the offset...
Old Jan 14, 2010 | 10:54 PM
the7thsin's Avatar
the7thsin
Default Guess the offset...
Anyone that has a good eye for how different wheel offsets look on the Zs want to help me out? Here is a picture of how my rear rim sits at stock ride height with no camber adjustment. When the car is lowered, the fenders had to be cut (when cut it left about 3mms between the tire and fender). I am running 275-35-19 Bridgestone Potenza REs. The reason I ask is that JLine doesn't release offsets and I'm super curious. Any help would be greatly appreciated.
Old Jan 14, 2010 | 11:24 PM
r_seng's Avatar
r_seng
+12?
Old Jan 14, 2010 | 11:27 PM
Lee R's Avatar
Lee R
Looks close to mine....+18.
Old Jan 15, 2010 | 12:28 AM
TheFarmer's Avatar
TheFarmer
Old Jan 15, 2010 | 01:31 AM
AVmagneticZ's Avatar
AVmagneticZ
better pic to see where it comes out the top of the wheel well would help.
Old Jan 15, 2010 | 03:47 AM
duro78's Avatar
duro78
jline has some hot wheels just a lil pricey
Old Jan 15, 2010 | 03:55 AM
maXmood's Avatar
maXmood
Under Boost!
i would say 18+ as well
Old Jan 15, 2010 | 04:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if you want to know the offset, you can just measure it - it's the distance (in mm) from the centerline of the wheel to the mounting surface (where the wheel bolts to the hub)
https://www.rsracing.com/tech-wheel.html#backspace
Old Jan 15, 2010 | 07:05 AM
Thermal1's Avatar
Thermal1
How wide are the wheels?
Old Jan 15, 2010 | 07:12 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
+15 is my guess..
Old Jan 15, 2010 | 07:22 AM
scotts300's Avatar
scotts300
No one can make a guess - at least not an informed one - without knowing the wheel width. It is impossible. Anyone making a guess otherwise is simply throwing a dart or making assumptions.
Old Jan 15, 2010 | 10:26 AM
the7thsin's Avatar
the7thsin
Z1: Thanks for the link. I actually took a look at it before but have just been too busy to get out to my car and measure (I don't drive it often and work/life > me). Maybe I'll try to get to it tonight...
Everyone: Sorry. The wheel is 19x11. I don't have any pictures from above. I could take one, but I need someone to tell me how far the lip of the fender is from the pavement on a stock suspension so I can readjust for the picture.
Old Jan 15, 2010 | 11:22 AM
scotts300's Avatar
scotts300
Everyone: Sorry. The wheel is 19x10. I don't have any pictures from above. I could take one, but I need someone to tell me how far the lip of the fender is from the pavement on a stock suspension so I can readjust for the picture.
Take 10 minutes to pull a wheel off to measure it. The center of the wheel is 5" from either side - mark that. Then measure from that point to the mounting surface of the wheel.
It's also highly-likely that the offset is stamped inside the wheel in on the back of one of the spokes or there is a sticker that says the wheel size and offset. That's pretty common.
Old Jan 15, 2010 | 11:38 AM
the7thsin's Avatar
the7thsin
Yeah, I'm going to measure it tonight when I get home. I just need to finally make the time. As far as the stamp/sticker... JLine doesn't do either. They're actually known for not disclosing offsets. You either tell them it is for a (x) car and they have their own optimal offset they use/don't disclose or you order with a custom offset. These were ordered the former way. I'll report the findings back.
Old Jan 16, 2010 | 07:27 AM
AVmagneticZ
Well this was a fun guessing game but then all the smart people chimed in and ruined it
416blueZ
Jun 11, 2024 10:56 AM
350z82
Oct 1, 2015 06:25 PM
416blueZ
Sep 24, 2015 02:11 PM
